When to retire the car?
Discussion in 'Gen 2 Prius Main Forum' started by JMalmsteen, Aug 17, 2017.
  1. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    just curious were these the original batteries in the 2007? sorry if i missed that if it was previously mentioned
  2. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    We just replaced the battery at 469k miles!
    James1964 and SFO like this.
  3. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    James1964 likes this.
  4. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    Wow, nice. And here I am wondering sometimes about my '14 (yeah different generation i know) making it to 225k safely without major battery issues
  5. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I wouldn't be the slightest bit concerned.
    MilkyWay likes this.
  6. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    I mean i'm not loosing sleep over it but the car won't be paid off until it has approx 160k miles on it (i do between 25 and 30k a year), so i just always wonder how many years i'll be able to drive it payment free :)
  7. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I assumed you were near 225k now, and that scared you.
  8. JMalmsteen
    287
    266
    Put away 3k now if you can, in an oh s$%& fund in case something explodes like the battery. People have reported major repairs from under 100k.
  9. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Just set aside money so you have 3k by around the 10 year mark for the inevitable battery failure. Then you'll be good at least another 10 years!
  10. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    This line of thinking (that the battery WILL die, and that it will be the ONLY major problem) is incorrect and potentially dangerous. There are a bunch of very expensive things that could fail on a Prius, and although they don't all wear the same way, many have fairly similar odds of failing. And those odds increase with age, mileage, and wear and tear (temperature, weather, driving surface, etc.). Regular maintenance is the key to having the car last as long as possible, but beyond roughly 15 years and 200,000 miles (and sometimes before those markers), anything can happen.
    frodoz737, Raytheeagle and Merkey like this.
  11. JC91006
    16,936
    8,647
    Yes this is correct. I bought a project 2010 Prius that started with oil burning, which then had EGR issues that had shaking at startup, then lead to head gasket failure, then lead to O2 sensor errors, and this will eventually lead to Catalytic converter failure. And when it reaches about 10 years old, there will be a battery failure. $3000 wouldn't cut it
  12. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    It is true that one should set aside more than $3k for car repairs. I meant, but poorly explained that one should earmark 3k just for the battery, assuming that is a time/wear item, and more $$ in case of other repairs.
    I personally like to keep at least $10k aside for car repairs myself. As a former owner of European makes (Range Rover being my worst experience by far) I'm always wanting to be prepared for the next problem. I will say that my 06 Prius has by far been the most reliable car I've ever owned, like many others have said.
    Aaron Vitolins and Raytheeagle like this.
  13. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    My car is only worth $3000 I would never put $3000 into it....The battery problem is a huge myth and a joke...People will put $600 in tires, $200 on the 12V, and $500 in suspension and walk out of the shop as if nothing happened ---- but totally freak if they need to replace the traction battery. A shop near me charges $400 to rebuild the cells...Very cheap fix.
    James1964 and johnnyb588 like this.
  14. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    One thing I have never understood about this position is that it does not take into account the cost/value of a replacement.
    If the car needs to be replaced, then the cost of a replacement vehicle needs to be considered in the assessment of a repair. Sometimes it might not be worth it to make a $1k fix on a $2k car. Sometimes it might be worth it to make a $2k fix on a $1k car. It all depends on what the replacement vehicle is, in my mind.
    JMalmsteen, srellim234, Rph74 and 2 others like this.
  15. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    oh my goal is to get the car to 225K, should be about 9 years. and then replace it. My drive is too far every day to risk going much beyond that. Plus i will have driven about 3 years at that point with no payment, so I'll have money saved up for down payment on new car
  16. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Can I ask you a few questions. What was your maintenance like regarding oil changes and oil used? Also, was it pretty much only driven on long highway commutes or did it also have a lot of city miles? Did you do anything to help prolong the use of the battery?
    I'm honestly amazed by 470k miles. That would be awesome. I'm in the process of shopping for a low mileage 09 and would love to replicate whatever maintenance you guys did that led to such great usage.
    Stephen
  17. JMalmsteen
    287
    266
    I changed the oil at 5k, sometimes as much as 8k if I didn't get around to it. I did no preventative maintenance for the battery (whatever that would be?!??
    We did next to no maintenance, just the 120k mile services and oil change, no preventative maintenance beyond that. We didn't follow the 5k things in the guide either. We went to Toyota for the 120k and the shocks and brakes (once).
  18. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    What kind of oil did you guys use? (Brand and weight). Did you need to increase weight as the miles racked up to keep it from burning too much oil or anything like that?
  19. bisco
    52,855
    every now and then, you get a keeper. don't read too much into it.
    JMalmsteen, Raytheeagle and MilkyWay like this.
  20. JMalmsteen
    287
    266
    Nope. Same 5w30 that's recommended. We didn't do anything special. It has been burning a quart of oil every 500-1000 miles for years at this point.
    Rph74 likes this.
