When you need a tiny bit more Ev range
Discussion in 'Prime Main Forum (2017-2022)' started by Lee Jay, Jul 10, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Two days ago, I missed making it home on Ev only by 0.3 miles. The engine went through warm up and then I got home.
    Today, I made it by 0.1 miles. I had to sort of coast to the top of the hill near my house. I then regenerated 0.6 miles of range as I drove the last mile.
    A few weeks ago, I missed it by 0.1 miles.
    Another time, I made it by 0.1 miles and yet another I missed it by 0.8 miles.
    That's in 3 months.
    My point is, I'd like a button that would prevent the engine from starting and instead give me the couple of extra miles of Ev range stored in the battery that would normally be for hybrid operation. From what I understand, some other cars have such a button.
  2. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I usually succeed in keeping ICE off by driving like a snail when no one is behind me! I agree with you about ICE kill switch.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes my Ford Energi has this tech except it's not a button; it does it automatically (can be turned off in menu) after learning common destinations like home, work, etc. They call it EV+ mode.
  4. bwilson4web
    16,535
    Just a thought but Google Earth can give you a fairly accurate altitude profile along any defined route. If you can safely minimize the speed going up grade, it will reduce the highest loads and greatest energy losses. On the downgrades, you might want to experiment with "N" vs "D".
    Have you checked the tire pressure recently? Perhaps time to go to maximum sidewall?
    GOOD LUCK!
  5. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    So yes, N and D would both work on larger downhills, but are you saying that N is better as it would recharge the battery faster? How about the best mode to be in? EV, HV or Auto EV?
  6. Lee Jay
    5,850
    4,036
    Believe me, I'm way past that. The trip that I made it on was 32.5 miles, the trip I almost made it on was 35.5 miles.
    I just have these few trips once in a while where I could use like <1 mile of additional range, and the car already has it, but won't let me use it until the engine is started and warming up - needlessly.
  7. bisco
    52,855
    we've been asking for this button since fotomoto told us about his ford. it's in the 'what do you want in the next pip' thread over and over. it was disappointing that toyota didn't embrace it.
    i can't tell you how many times my engine his come on within a mile of my destination, and many in the last few feet.
  8. fotomoto
    5,639
    3,815
    So. Texas
    Ford most likely has a patent on it. Why wouldn't they?
    Trollbait and bisco like this.
  9. bisco
    52,855
    if it's patentable, i would. genius.
  10. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Could it be that Toyota is protecting the traction battery by not allowing it to be discharged below certain percentage? In a LEAF forum, I've read not to leave battery below 20% or above 80% because charging in low/high areas makes the degradation worse.
  11. Lee Jay
    5,850
    4,036
    Yes, but they do let it get lower. Example percentages:
    Hybrid mode - 15%-25%
    EV mode - 25%-85%
    What I'm asking for is to be able to use about half of the hybrid mode portion, which it uses anyway during warmup (because the engine isn't really propelling the car during that period) just without the engine warmup happening.
    Prius from Dad and bisco like this.
  12. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Make sense. When the expected travel distance is slightly beyond EV range (for me, it may be 38-40 miles with my local driving), I experimented with switching to HV on Hwy when EV range dropped to minimum I need off Hwy v.s. letting the traction battery being used up. It is vain of me to care about this, but Eco score board shows better MPG with latter. So, I most often just let the battery used up on Hwy. I find that Prime is more agressive in utilizing battery even in HV mode compared to PIP.
    Prius from Dad and dalcon95 like this.
  13. Nic Steussy
    Nic Steussy Junior Member
    27
    22
    Indianapolis
    My experience is that when I punch over from EV mode to HV the battery just keeps on powering the vehicle - presumably drawing from the HV portion of the battery.
  14. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    What does the Prime do when the gas tank is empty and your out of EV range?
    'LectroFuel likes this.
  15. Nic Steussy
    27
    22
    Indianapolis
    I've got plenty of gas. I usually save 8 - 10 miles of EV range for the end of my commute. So, I'm tooling along at 55 mph in EV and push the button to switch to HV. According to the energy transfer screen the motor doesn't start up for 2 - 5 miles. I presume that lag is driving the car in the HV portion of the battery.
  16. Lee Jay
    5,850
    4,036
    It stops.
  17. bisco
    52,855
    It may still use the battery, but it's the ice firing that'a the problem.
    Even if it only let you do it every so many miles, it would be great.
    dalcon95 likes this.
  18. Rmay635703
    2,702
    1,729
    2013 Chevy Volt
    My Volt doesn't
    If the tank is empty and I have zero miles of range it goes another 3-6 miles in what's called reduced propulsion mode.
    The tank is monitored very closely so the engine does not fire until you add about 1.5 gallons of fuel.
    My guess is the Prime would do the same but someone would need to test it and make a tank spoofer if it works
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    There have been several times when I've run out of EV range a few hundred feet from home. It's really frustrating to know that the battery could still get me there, but now I've got a cold engine to let run long enough to warm up (which only takes about 2 minutes here this time of year). Sure, it's charging the battery, but I can charge it cheaper on home current. Not to mention the time involved. How hard would it be for the engineers to program in some kind of override?
    The only reason I can think of not to do that is that, while warming up, the car still draws quite a bit from the battery to reduce the load on the ICE. If you ran it down too far using some kind of override, it might violate the programmed rules for battery assist during ICE warmup. But I would think it could spare a couple percent for those situations.
  20. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    Wow, is it worth to actually sit there while the engine warms up before you turn it off and leave the vehince? I guess I would just want to get home ASAP and switch the engine off, even when it's not warmed up... I mean, are you really doing that much damage to the engine by switching it off while still cold?
