Where’s the aftermarket wheel/tire thread?
Discussion in 'Gen 5 Prius Main Forum' started by Chi_weezy, Feb 14, 2024.
  1. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    This is just a matter of getting the right hubcentric rings.
  2. Chi_weezy
    Chi_weezy Junior Member
    35
    Sacramento
    2024 Prius Prime
    ^ Aright,
    Ferrada FR4 19x8.5 +35mm Black 5x4.5 with 235/40’s. Sweet setup imo. $2k wheels.
  3. Slipangle
    Slipangle New Member
    NorCal
    2023 Prius
    Looks great. Any rubbing? Searched online and apparently they are a whopping 31 lbs though.
  4. Downrange
    Downrange Active Member
    372
    212
    2024 Prius Prime
    SE
    here are Borbet Type W 17x7 with stock Toyo Extensa, will try photos. IMG_0859.jpeg IMG_0864.jpeg IMG_0864.jpeg
    PandaBOT, villageidiot2 and PhoS like this.
  5. otatrant
    otatrant Active Member
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    MSW Type 48 17x7.5 with Michelin CrossClimate2 size 205/55R17
    Humble Bear likes this.
  6. Downrange
    372
    212
    2024 Prius Prime
    SE
    Sorry for double photo - still getting the hang of photo posting. The Borbets are my second set - I liked the wife's Type F Black ones on her XLE-AWD so much I got the silver Type W for my Prime. They were blowing them out at Tire Rack for awhile. Don't know if they still have stock, but I sure like them. Solid but not too heavy.
  7. Chi_weezy
    35
    Sacramento
    2024 Prius Prime
    ^ More pics if you can. And what offset?
  8. Downrange
    372
    212
    2024 Prius Prime
    SE
    Slipangle and Chi_weezy like this.
  9. Downrange
    372
    212
    2024 Prius Prime
    SE
    40mm I think. Tire Rack supplied the centering ring thingies. They also sell TPMS that work for under 50 bucks apiece.
  10. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    Got mine all mounted up. 19x8 +48 Ray's w/ 245/40/19. Please excuse the grime, were in the middle of a massive winter storm.
    I probably said it before in another thread but I don't think you can go much below a +45 offset on a lowered car without chopping stuff or going with a smaller tire. The fitment on mine is quite close but it doesn't rub.
  11. Chi_weezy
    35
    Sacramento
    2024 Prius Prime
    Looks good! You CAN go below a +45 offset if your wheel width is less. That’s kinda how it works
  12. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    since you quoted my post about the hub spec, do you have a measurement of the ID for the hub centric rings (if they were needed )?
  13. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    Yea but sub 8" wheel selection more uncommon. Then you run into the issue that you wont be able to match the stock diameter tire. 225/55/17, 245/45/18, or 245/40/19 are the ideal sizes. If you want more narrow than a 8" you're pretty much stuck going to an 18 or smaller.
    60mm
    Agent337, Chi_weezy and vvillovv like this.
  14. Slipangle
    NorCal
    2023 Prius
    Since you lowered your car did you readjust camber after lowering? Just thinking if there’s sufficient camber gain if left at stock height to allow for wider wheels and/or lower offsets. Of course if you readjusted camber after lowering then you would not be getting that camber gain.
  15. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    I didn't realign after doing the springs. I was fully expecting to have to add camber to clear the tires but got lucky. The camber change from my drop amount was actually very little (4-5mm-ish at the top of the wheel) The rear gained even less after lowering. (2-3mm)
    I'll be getting it realigned after I do the front sway bar since you basically have to take the front of the car apart to get it in there... Curious to see what the values are currently compared to stock.
    #35 PhoS, Mar 3, 2024
    Slipangle likes this.
  16. Chi_weezy
    35
    Sacramento
    2024 Prius Prime
    I’m still trying to find the right wheels… design wise, in the right size..
  17. otatrant
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    What kind of Continental tires are you using? How do you like them?
  18. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    They're the DWS 06+ , they have been excellent in the heavy rains as of recent. Haven't really put that many miles on them yet in the dry.
    otatrant likes this.
  19. Justin Prius AWD
    Justin Prius AWD Junior Member
    37
    2024 Prius
    Limited AWD-e
    Looks great! What are your thoughts on a 18x8 +40 wheel with 225/50-18 tire lowered on RS-R springs? I just checked clearance and there is maybe an inch. Wondering if I should cancel my order with DT now.
    #39 Justin Prius AWD, Jun 19, 2024
  20. pendragon
    pendragon New Member
    So Cal
    2023 Prius Prime
    XSE Premium
    RS05RR 19x8.5 with 245/40r19
    Saw you commented in original thread a while but went on a business trip and forgot about the post for a while, sorry but I'll just respond now lol. MPG went from 48avg -> 43avg so a pretty noticeable drop but I'm coming from 19mpg so it's still an upgrade :LOL: Note these wheels are 2 inches wider than the stock ones lol. Did you end up picking a wheel yet??
    #40 pendragon, Jun 20, 2024
    JoeBlack likes this.
