WHERE ARE THE JACK STAND POINTS ON GEN.2?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 12, 2023.
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
  2. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    They are in the same place that they have been on almost every Toyota model for the last 37 years rocker panels you'll see little cutouts You put your jack plate between the little cutouts in almost fits perfectly I'm talking about a floor jack If you want to whip out your cars Jack the cutouts line up almost perfectly with it I never used the car's jack there are two on each side You can also lift up on the front tow point which is where there's a circle in the little doodad up there that you can put a rope through You can jack on that too there are spaces in the back where you can jack so I'm going to be a long shortly and we'll post up a picture for you with the underside of the chassis with a bunch of ink circles around it You can jack there too Good luck
  3. Mendel Leisk
    42,325
    This is a 3rd gen pic, but second gen is very similar. What I've been using, for 12 years, 24 oil changes, 24 tire rotations, 3 transaxle fluid changes, and maybe half a dozen miscelanious forays:
    Front location:
    Regarding the use of jackstands at the "proscribed" scissor jack placement points: try the scissor jack, place in position, start up, and you'll see: it is not touching that bottom edge. It is notched around that edge, actually bears on the sheet metal behind it. And dimples it in readily, even at the rear location.
    Rph74 likes this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    #4 Georgina Rudkus, Jan 12, 2023
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  6. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    2008 and 2010 service manuals for front and rear jack points and for jack stands, on the rocker panel pinch welds.
    #6 alftoy, Jan 12, 2023
    SFO likes this.
  7. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Nice, thanks for sharing this I always use ramps for fluid changes and a Jack/Jack stands when I have to work with wheels removed.
  8. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Hyper Tough close.jpg Here's a prototype special Toyota-Lexus jack stand pinch weld adapter that I am working on with my husband and his friend.
    SFO likes this.
  9. Mendel Leisk
    42,325
    Meh, this works like a charm, simple and solid.
  10. erkq
    erkq Junior Member
    How do you get a ramp to the front wheel with the low rocker panels and air dams? I'm tempted to build my own out of blocks of wood.
  11. alftoy
    1,132
    519
  12. erkq
    erkq Junior Member
    Yep... that certainly looks like the answer. Thanks!
    I made an appointment to get the downstream O2 sensor replaced, just in case.
  13. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Do not know why I bother, but has anyone tried RTFM.
  14. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Can you jack up the vehicle and place the ramp under the wheel?
    Pretty simple job (with the correct socket), and depending on the amount of clearance you need, you might drive the right side onto a curb.
    Let us know if you use a sensor other than OEM/Denso and if it works.
  15. Mendel Leisk
    42,325
    If a purchased ramp is too steep, you could put a piece of 2x8 or similar on the approach, whatever it takes to improve clearance. Or DIY some ramps out of timber (say 2x8 or 2x10 on the flat), that do clear. Cheap as dirt and effective.
    #15 Mendel Leisk, Mar 18, 2023
  16. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I bought a set of Rhino Ramps for low profile cars about 25 years ago and they work for the Prius. The lower air dam barely touches the ramp, but once I get up the ramp, no contact at all. I’ve used these on my 06 for almost 10 years for all of my oil changes.
