Where are the left and right blinker wires?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by arek, Oct 18, 2018.
  1. arek
    arek Junior Member
    97
    Hi Peeps,
    I will install the Avest side mirror blinkers so I’m looking for the left and right blinker hot wires as well as the ACC and 12+ wires. I want to avoid tapping into the fuse. Can anyone direct me to the necessary 4 wires? Thanks!
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    I don't think that the blinkers have "wires." I think that the lights are probably controlled by the CANbus, which is a digital signal based system. The blinker command is coded and sent to the CANbus and applied at the light location by a decoder. In othervwords, there are no separate "wire" circuits. Rather, individual components are all hooked to the CANbus and function when the proper signal is on the network wire. At least that is my rather rudimentary understanding.
  3. William Redoubt
    1,228
    1,172
  4. Elektroingenieur
    2,515
    3,284
    Three Touring
    That may be true of other vehicles, but not for any Prius cars to date, which use conventional turn signal wiring. On the fourth-generation Prius and Prius Prime, the current for the turn signal lights is switched by a flasher circuit in the combination meter assembly.
    The wiring is shown in the Turn Signal and Hazard Warning Light section of the Electrical Wiring Diagram, excerpted in the thread you kindly linked and available by subscription to techinfo.toyota.com.
  5. sdhzlgl
    sdhzlgl Junior Member
    32
    montereypark
    左侧和右侧都有信号灯线束,你可以看到我的帖子,有照片,需要电笔测试,很容易找到。
  6. Rexq
    Rexq Junior Member
    47
    Followed this guide:
    Avest Side Mirror install | PriusChat
    Prius Prime Premium will not have the yellow and blue wires.
    For the Premium Trim, use the purple and green wires.
    Hope this helps anyone else looking for it.
    144505_2018-04-05_17_19_34-Left_Mirror_-_OneNote.jpg IMG_9998.JPG IMG_9999.JPG
    Mark57 likes this.
