Where can I buy cruise control parts?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Funk-O-Meter, Sep 14, 2012.
  1. Funk-O-Meter
    Funk-O-Meter Junior Member
    33
    Where can I buy the parts for the cruise control retrofit for my 08'? Can they be purchased in a kit or do I have to buy them seperate by part number?
    Thanks.
  2. Bradkb
    Bradkb Junior Member
    Kent, UK
    These are the parts you need, I have just completed it on mine, I got the cruise stalk and wiring on ebay, and the steering wheel cover and brake light switch from my Toyota dealer, total cost less than £80
    Main Cruise Control switch 8463234010
    Cable to connect the switch 8463348020
    Steering wheel right lower cover 4518647010C0
    Stop Light Switch 8434020060
    Took about 20 minutes to complete, if you do not change your stop/brake light switch, then it will not function, the cruise indicator will light on the dash board, but it will not engage.
  3. Funk-O-Meter
    33
    I see so I just orderth wherever I can find them. Thanks.
  4. omegacb
    omegacb Junior Member
    UK
    I want to retrofit cruise control to my Nov '07 T3. I understand how to fit the parts but I'm still really confused about which stop light switch to order. This post quotes 84340-20060 and I have seen 84340-47020 mentioned elsewhere. Are these switches interchangeable - if not is there any way other than trial and error to know which one will work?
    Thanks
  5. Carltona123
    Carltona123 New Member
    Solihull UK
    Hi Brad
    I'm thinking of fitting CC to my 2007 T3.
    Can I ask how you went about getting the air vent off? Is the wiring to the power switch likely to cause a problem?
