Where can I find this accessory?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by FabianG43, Feb 19, 2013.
  1. FabianG43
    FabianG43 New Member
    Just bought a 2010 Prius IV and noticed these two areas didn't come with a mat or some kind of material to cover the plastic to prevent items from sliding. As well, I don't like the bolt being visible. Where can I find an oem cover/tray/mat for these areas? Something made of thin rubber would be nice.
    Thank you
  2. peterjmc
    917
    189
    Clarksburg, MD
  3. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I have the carmate also and it is nice. A couple of DIY options would be some felt or maybe a thin rubber pad (you can buy sheets at Hobby Lobby).
  4. FabianG43
    thanks for the tips
  5. Netbook
    Netbook Junior Member
    47
    17
    That is what I did to mine.
    frodoz737 and Jerry Mcl like this.
  6. Tim Powell
    Tim Powell Member
    42
    25
    Central Florida
    Is that felt? What did you use to glue in place?
    ES44AC and Jerry Mcl like this.
  7. Netbook
    47
    17
    It is felt. It comes in 8.5 x 11 sheets with adhesive on the back. I used paper to create templates and then cut the felt to fit. It is sold at many fabric and craft stores. Here is one I my area.
    Home : Shop | Joann.com
  8. Tim Powell
    Tim Powell Member
    42
    25
    Central Florida
    Thank you! Looks like this weekends project.
  9. Wayward
    Wayward Member
    145
    26
    Idaho
    As an FYI, I bought a similar pack on ebay, except it was only like $30 delivered for the pad set for my car, not the $100 that one was.
    It's basically made out of mouse pads. If you were to buy like 4 or 5 of those jumbo mouse pads for $5 each at a Fry or similar place you could cut your own pretty cheap. They seem to work really well though.
  10. Wayward
    Wayward Member
    145
    26
    Idaho
    Ok I went and looked up my history this is a similar listing to what I got, this one is for a Camry and it's $30, you could always contact the seller and see if he has one for a Prius again. I have done that in the past with sellers and they have turned around and relisted an item for me right away, just a thought.
    Non Slip Foam Pads Toyota Camry Dash Console Doors | eBay
  11. RRxing
    RRxing Senior Member
    2,558
    1,833
    NEPA
    OT - Has anyone ever come up with a definitive answer to the purpose of the notch on the left side of the upper glove box?
  12. Netbook
    47
    17
    It is for an umbrella.
  13. southernguy
    southernguy Junior Member
    55
    Fits a wine bottle
    avillan610 likes this.
  14. Netbook
    47
    17
    I received both these as private messages. The forums are meant to be forums for one person to post and many to read and learn. I am answering the questions here in the forum and not in a private message.
    I used standard 8.5x11” paper and a pencil to create the templates. You can jam a piece of paper in an area and draw a line, then cut that section out, then draw a new line and cut that section out, when done you will have a section of paper that fits perfect in the section you want to cover. Then you take that piece of paper and lay it on the felt. Then you cut a piece of felt from that template and stick the self adhesive felt to the section. Then find a new section and do the same thing until done.
    The felt I used was black. The flash does make it look gray. It looks the same as a Lexus glove box. The entire project took about 90 minutes. I now have 104,000 miles on the car and think that 90 minutes paid off.
  15. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Excellent work!
  16. nivlac915
    nivlac915 Member
    77
    56
    up in the hills of covina, west side
    thanks netbook... next project on my list!! ;)
  17. ES44AC
    ES44AC C.A.U.S
    319
    77
    Very nice professional job! I hope it stops those rattles that seem to emanate from whatever I put in those silly boxes!
