Where can I find this fuse?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 11Priuz, Sep 15, 2022.
  1. 11Priuz
    11Priuz New Member
    Houston
    I have 2011 Toyota Prius. One of my lights is out I changed the bulb and it still doesn’t work so I am assuming It’s a fuse. I’ve had the fuse go out before. I want to purchase a new fuse but I don’t know where to find this particular fuse. See images below.
    52,776
    dealer?
  3. ChapmanF
    18,957
    Which light is out?
    And do you mean the 30A/30A/40A "ABS MTR 2" "ABS MTR 1" "P/I 2" triple fuse?
    Is the 40 amp P/I 2 section blown?
    That does supply power to the integration relay, so if it's blown, you should be without both low-beam headlights, and also horns, backup lights, and rear window and mirror defoggers.
    If you only have one light out and not all that stuff, I would be looking elsewhere.
    The part appears to be this one:
    2011 Toyota Prius Fusible Link. ENGINE ROOM FUSIBLE LINK; FUSIBLE LINK - 9098208308 - Genuine Toyota Part
    Raygon likes this.
  4. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    Why would you assume the fuse is bad when you can put it ohmmeter on it and be certain
    Raygon likes this.
  5. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Looks like it will blow again until you find out what the real problem is...
    douglasjre likes this.
