Where did you mount your ScanGuage II?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Rainking, Mar 3, 2016.
  1. Rainking
    Rainking Member
    164
    New York
    Where are you mounting your ScanGuage II? I currently have mine on the steering column via velcro (like most people) and I'm getting tired of not being able to see the bottom row of gauges properly and want to figure out a better mounting position. So post up what you got. Thanks!
    I did a quick search and did not find any recent good threads with pictures.
  2. Mendel Leisk
    42,264
    I set mine a little further back, on the dash. I "temporarily" secured it with a couple of loops of masking tape, acting like double-sided tape. It actually stays on there fine, so I left it like that. I'll pull it off to clean the dash, every once in a long while, doesn't leave any residue. We're garage stored though, not parking in hot sun that much. Visibility is ideal in that position.
    Rainking likes this.
  3. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Most people mount right in front of the steering wheel.
    Here's my setup.
    James Powers and Rainking like this.
  4. Rainking
    Rainking Member
    164
    New York
    Nice! Where did you get that mount from? Link? Thanks!
  5. Xterra72
    1,437
    1,684
  6. Rainking
    Rainking Member
    164
    New York
    Xterra72 likes this.
  7. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    I also mounted it to be immediately visible through the steering wheel, but I shaped a wood block to the required compound curves of the dash to serve as the base. It seems to be both durable and stable, so next step would be to paint to match the dash.
  8. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    I made a mount and used industrial strength Velcro to put it above my wide mirror.
    I can see it at a glance, and the steering wheel doesn't obstruct the gauges while turning. ;) 20171121_105609.jpeg
