Where do I get 12 v Power for a Hard-Wired Accessory?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Larry_C, Aug 21, 2012.
  1. Larry_C
    Larry_C Junior Member
    Spokane, WA
    Dumb question, I know.
    I am installing and FM modulator in my 2008 Prius. It requires power. Where do I run the black and red wires? Are there pictures or diagrams that would guide me to the exact spotto splice a power wire? I am handy around the house but working on a car is a different world for me.
    Thanks!
  2. Larry_C
    Spokane, WA
    Additional notes:
    Here is the modulator if that makes a difference: Amazon.com: Scosche FM-MOD02 Universal Audio Input FM Modulator for iPod, Satellite Radio or Portable Music Player: Car Electronics
    I'd prefer to hook it up to switched power--so it turns off when the key is removed--but I don't care too much, since it has a lighted power indicator to remind me to switch it off.
    I did install an aftermarket stereo in my 1971 VW campervan, so I thought I could do this, but the Prius wiring is nothing like that 40-year-old VW!
  3. Larry_C
    Spokane, WA
    Hmmm...are these boards dead or did I piss someone of?
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I was wondering the same thing. I was looking at hardwiring my extra Droid with the Torque app and Bluetooth scanner.
  5. R-P
    R-P Active Member
    808
    288
    Netherlands
    Will it work if it's only ON when the car is in "ready"?
    Then the most obvious choice could be to tap into the cigarette lighter*.
    My previous owner had tapped into a constant +12V somewhere. I found this when dismantling the dash where I found an extensioncord with a cigarette-lighter-socket and a 12VtoUSB cigarette lighter plugged into it. Luckily the powerdraw was minimal, as the darn thing was ALWAYS on...
    *: either just use a plug in the middle storage area or dismantle the dash and tap into the actual wire feeding it. I would not know a better solution.
    Larry_C likes this.
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I read somewhere if you wire it to the one under the radio console it will work (always ON part.. i don't know) - there was something said about wiring it into the one in the center console that made it not a good option. I'll try to find the link.
  7. R-P
    R-P Active Member
    808
    288
    Netherlands
    I thought they were both always off when the key was removed, but I hardly ever use the one next to the radio. So not sure...
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    As mentioned b4, the 12V outlet is switched and easy to get to. I would recommend that. The wires are accessible from the bottom of the dash (no removal required).
  9. Larry_C
    Spokane, WA
    Thanks, friends. I will poke around the 12V outlet this weekend see if I can figure out how to tap into it without breaking anything. I take it that I would splice my wires into the existing ones? Do I need to solder them back togther, or can I wrap and tape the way I would speaker wires?
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    I would use the wire taps you buy at an auto parts store. No soldering or taping required. This should be fine for this application.
