Where do you all change your transmission fluid?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by something_1942, Jan 1, 2016.
  1. something_1942
    something_1942 New Member
    Mcallen
    Local dealership wants to charge me $400 for it, I figured I could just get the stuff I need and bring it to walmart so they can put it on the lift and change it with my oil for $10-15. Where do you guys get it done?
  2. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    They are trying to charge you for a flush like regular automatics on other Toyota cars...which is standard book. Press your Service Adviser to look it up again. Prius is just drain and fill like engine oil and normally ranges $100-$150 at the Dealership. I went through this once. Otherwise, the procedure is here and can be done anywhere the surface is flat...yourself.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Mine (gen3) wanted 375$, it was considered a trans-axle service.
    The gen2 is a quick drain and fill.
  4. frodoz737
    4,720
    2,517
    33
    They are both quick drain and fill. The Service Adviser is/was trying to pad the bill...his commission. These are the facts.
    CR94 likes this.
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I do it myself--costs $40 for the fluid. It's little different from an oil change--more difficult to fill, but no filter. If I couldn't do it myself, I'd check with local garages and supply the fluid.
    It's just a few gears and two motors sitting in an oil bath. It's not a traditional automatic transmission where the fluid does work under pressure shifting gears and in a torque converter. Way different duty and different maintenance requirements.
  6. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    Luscious Garage in San Francisco is around the price range @frodoz737 mentioned, between $100-$150.
  7. Mendel Leisk
    41,901
    It is a VERY simple operation. If someone's telling you they'll do it for $400, do no use them, they are completely asea as to what's involved. Simple drain and fill. Maybe someone can PM you the second gen Repair Manual instruction?
    It's on par with an oil change, the fluid (Toyota ATF-WS) slightly more cost than for an oil change, depending on what brand of motor oil you're using. Anything over $100 to get it done by pros is excessive, for sure.
  8. Stevewoods
    Stevewoods Senior Member
    663
    1,200
    Seattle, WA
  9. jtegf
    jtegf Junior Member
    SUN CITY
    Okay, four quarts of Toyota WS from a dealer is approximately $40-$44.
    Four quarts of Valvoline Maxlife transmission fluid will bring that total down to $30 or so. Their spec sheet shows it to qualify as replacement for the original WS.
    My procedure is to run the front tires up on ramps, put a carpenter's level on the driver's door sill, jack up the rear end until the bubble is centered on the level, and change the fluid.
    Be SURE to loosen the filler plug to allow air to enter the case before you pull the drain plug unless you want a real mess all over! I learned that one the hard way......
    Use a funnel with a skinny lower spout so you can shove some 3/8" clear tubing over it and thread it down from the front, through the hoses, etc., into the filler hole. At somewhere around 3.7 quarts added, give or take, fluid will start to back out of the hole. When it stops dripping, put the plug back in. Mind the torque values for those two plugs and make sure you keep the filler tubing CLEAN when you poke it into the transaxle case! That's all there is to it.
    If you don't have a 10mm hex socket for the drain plug(Allen head) or a torque wrench, ramps, or a floor jack, let someone with a shop do it. BUT, take them the fluid and insist they use that spirit level on the door sill.
    While up on the lift, he or she can tweak the car level with a transmission/muffler stand under either the front crossmember or the rear jack point depending on which way the bubble is drifting.
    By the way, the drain plug for the hybrid drive is in dangerously close proximity to the transaxle plug, so MAKE SURE you pull the correct one! Trans is the one to the right (looking from the front of the car) and farther toward the rear of the vehicle.
    Did my 3rd change at 120k and it gets faster each time with the tools all ready to go, now taking about 30 minutes.
    tommymommy likes this.
  10. Mendel Leisk
    41,901
    If you've done your third change, and have 120k, there's no arguing with success. Still, I'd rather not gamble with alternative fluids, to save $10 every 2~3 years.
  11. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    An independent Toyota shop did it for one hundred
  12. tommymommy
    tommymommy Member
    120
    I buy the fluid at Toyota for around $40. Put the front on ramps, jack up the back until level (I use a level in the door frame), place jack stands for additional safety. Open the filler nut on top, then open the drain plug. I allow to drain while I go do something else, then come back and fill using 3/8" clear tubing on a funnel. It takes 3.7 or so quarts. It's as easy, if not more so, than changing the oil. *** Make sure you do not crack the coolant plug. If it looks like water, you've got the wrong plug.***
  13. frodoz737
    4,720
    2,517
    33
  14. tommymommy
    tommymommy Member
    120
    Yeah, DOH! I actually had a mechanic tell me there was water in my transaxle fluid because of this. Obviously he was an idiot and I was a bigger idiot for thinking he knew what he was doing. Now I change it myself.
  15. frodoz737
    4,720
    2,517
    33
    Not the Dealership I take it.
  16. tommymommy
    tommymommy Member
    120
    No. Although, they haven't been much better in my area. Hence why I now do my own work.
  17. frodoz737
    4,720
    2,517
    33
    If you know what you're doing, that is always best. The problem with most folks is they can't or won't. :rolleyes:
  18. tommymommy
    tommymommy Member
    120
    True, but I'm not most folks. :) I'm a woman with small hands and small stature with an even smaller wallet. I cannot/ will not pay for something I can do. Traction battery. NO way! Can't lift it. Have the knowledge to replace it. Struts, need extra muscle, but not hard to do. Same for both coolant loops. Of course, my stealership is convinced one can be electrocuted changing the oil on a Prius. Geez! I'm female, not stupid.
  19. Lucifer
    1,014
    486
    Nh
    10% of golfers break 100, fewer drivers (%) change their transmission fluid, lighten up;)
  20. tommymommy
    tommymommy Member
    120
    I'm trying....this diet isn't working fast enough.... ;-)
