Where do you buy your motor oil from ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EdyJun, Jan 25, 2012.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Walmart 5 quart jugs less than $5 per quart. I only fill with exactly
    4 quarts with filter for oil change. At 10,000 miles when I change
    nearly 4 quarts comes out.
    al
  2. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I don't remember what the book calls for, but changed my oil and filter and 4 qts put it right on the full mark. Found the 0W20 at only one Walmart and it's 65 mile from me so I have to plan my trip there.
  3. fuzzy1
    10,454
    As of today, my local Costco still has only 5W30 and 10W30. But the last time I was in the nearest WalMart (pre-holiday), it had both single quarts and 5 quart jugs of 0W20.
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Walmart price check last week or so here was $26.48 for the 5-qt jug of Mobil-1.
    The 5-qt jug is Walmart branded Mobil-1 return special so you can return the used oil to Walmart in the same jug. I usually keep some empty 1-qt containers around in case I want to split the jug up.
