Where do you put your aftermarket GPS in your Prius?
Discussion in 'Gen 2 Prius Main Forum' started by ChaPrius, Jan 28, 2008.
  1. ChaPrius
    ChaPrius New Member
    Chappaqua
    i called Garmin to discuss the problem I was having with the suction cup not holding on the windshield of the Prius, and there was no other place on the dash that it would stick. They offered me the "friction mount" which sits on the dashboard at no charge. I took them up on it and I'm quite happy with it. Until I got it I was using the cup holder, and that worked fine, too, but it's nice to be able to use the cup holder for its intended purpose!
    Anyway, I though you folks would like to know.
  2. sweetguy
    sweetguy Junior Member
    85
    Maine
    I just bought the garmin bean bag mount (cheaper from Amazon than from Garmin) for my Garmin 660 and tucked it into the space by the left tiny window on the left dash. The wire fits nicely along the vertical space under that and along the bottom of the dash under the steering column. It never moves and I believe it is left of the air bag so hopefully, it won't kill me if I get into an accident.
  3. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Interesting. If it does kill you, will the GPS point to heaven or another place? :behindsofa:
  4. isipgas
    isipgas New Member
    I use the suction mount for my TomTom Go 510 on one of the cup holder covers in the center console. It's nice because it puts the GPS in a more ergonomic position (no reaching) and allows me to run the power cable discreetly to the outlet in the console. The only disadvantage is that you have to look away from the road to see the screen, but I generally just listen to the voice guidance.
  5. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    We have two Garmin hand helds. My eTrex Legend Cx was purchased for use on my jet ski. When using it in the Prius I have a suction mount with about a 10" flexible shaft. I put the suction cup on the little window behind the windshield and in front of the drivers window.
    My wife has a Garmin Nuvi 350. That one sits on the little swing down door below the radio as shown in other responses to this thread.
    The Nuvi 350 is very easy to use, has voice commands, and a nice touch screen. It's my first choice for use in the car.
    The eTrex is water proof so perfect for ocean rides. It has survived hundreds of hours mounted on the jet ski glove box cover where it sometimes gets constant salt water splash. The eTrex has many more features than the 350 but has a small screen, no voice, and no touch screen.
    Both units have their place, both are used in the Prius.
    jd
  6. LYLUVLY
    LYLUVLY New Member
    150
    Huntington Beach, Ca
    Welcome to PriusChat!
    Recently there have been a rash of break-ins due to GPS exposure, in Calif. We solved our problem by not having in clues. Our GPS fits perfectly on the CD door under the stereo. Our GPS fits exactly, so that it is held in place by friction instead of showing off a suction device or whatever. Once we park, we throw the gps into glove compartment, voila', no show!
    GPS black market is at the top of the list for stolen goods from autos. Our device is a Magellan
  7. RatedN
    RatedN New Member
    Houston, TX
    Like many, I disconnected the center speaker above the MFD for better sound quality. Since there's no use for it, I just took the speaker out and use the squareish hole as a GPS holder. The mount sits perfectly in the hole so as to make the GPS unit sit just right on top of the dash. I ran the power cable through the dash and plugged it into the front power outlet. For most drivers and passengers, you won't see much of the hole (unless you really crane your neck towards the dash).
    When I have time, I'm hoping to fabricate a cover to make the mounting look clean.
    If I have even more time, I want to fabricate a spring mounted door made out of the factory speaker grill, attach the GPS to the grill, and have it swing up when I want to use it and close down and lock when it's not in use. We'll see about that one.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Well I got it all fitted, no I haven't taken all that time I was doing other things.
    I also put the receiver for the tyre pressure monitor I purchased a while back. I can plug it in yet as I haven't got the sender units in the wheels yet, Friday I will.
    Before I started, see the consumption?
    Stripped down for the install. No need to remove any dash panels if your not hard wiring it in.
    This is held on with double sided tape and a huge amount of clamping force, doubt the tape is needed. You can see the power cable goes into the dash at the top of the vent panel. I stuck the power supply in front of the steering wheel in the dash, there is loads of space. Doing the wiring is why I pulled the dash apart.
    I put the base of the swivel mount as high and as far right as I could so it doesn't obscure the MFD.
    The phone mount has the second part of the swivel on the back. It is held on with a single screw with thread locker on it.
    Here it is all mounted, easy to reach, easy to see and hear.
    I hooked up to 12 volts here which I got from the back of the console. I hooked in to the power socket supply which can be reached by removing the rear cup holder, it just wriggles off. I mounted a second power outlet in back of the console and didn't wish to break into the original loom twice.
    No pictures of it but the tyre monitor has a plug for a cigarette lighter socket so I put a lighter socket behind the lower panel of the dash and plugged it in. This means simple hook up and a fuse in the circuit.
    The socket in the back to run a laptop for my son while travelling. Excuse the scratches.
    And the tyre monitor which as you can see isn't plugged in, yet.
  9. patsparks
    10,664
    567
  10. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    TomTom via suctioncup that sticks to the smooth part of the dash just below the center airvent to the left of the MFD (it would be to the right of the MFD for LHD models). Just the right width, sticks well. Leaves no ring on windscreen.
  11. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Velcro to Top of Dash, Left of MFD
    I put my TomTomONE on top of the dash, to the left of the MFD.
    My TomTom ONE came with a round flat dash disc, which accepts the suction cup. You can either stick the dash disc on with its adhesive backing, or use Velcro tape as a previous poster suggested and which is how I do it --- I don't want to alert thieves by leaving a very visible dash disc there.
    First photo below shows the Velcro squares on bottom of dash disc and top of dash; and the second photo shows the TomTom ONE in place:
      File size:
      158.3 KB
      1,060
      File size:
      157.7 KB
      1,097
  12. Yankees251
    Yankees251 Black Touring HI Package
    96
    Danbury, CT
    Re: Velcro to Top of Dash, Left of MFD
    You seem to defying physics with that teeny tiny piece of velcro, take any sharp turns with that setup yet?
  13. Boo
    5,051
    488
    97
    Flushing, NY
    No problems yet with the tiny Velcro square. And I actually don't expect to have problems. But I know what you mean. Eventually, I'll probably re-do it with 2 Velcro squares or a Velcro strip equal to 2 squares.
  14. rep308
    rep308 Junior Member
    71
    suburbs of Boston
    I've been a happy customer of pro clip usa ProClip Mounting System  - Choose Your Country for mounting my Garmin Nuvi between my different cars in the family. However the Prius design is big and ugly. I've found that I can just use the standard suction mount on the silver dashboard strip right next to the main display.
    Leaving the tell tale suction ring on your windshield is a good way to get your car broken into.
    I'm not looking to start a flame war but the Nuvi smokes the $2000 Denso unit that Toyota build into the nav system. I can also update the Nuvi maps much cheaper than Toyota charges to update the Denso.
  15. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I throw it in the passsenger seat and let it talk. :p
    If someone is with me, then it's with him/her.
  16. joeszabo
    joeszabo Junior Member
    39
    I have a Garmin Nuvi 260 -- I used a $15 suction mount from the web which I rigged up as a hard mount. This works great at it sits low enough to not be seen from outside the car (unless your really looking for it) which should deter break-ins to the car and high enough to be used by the driver (most useful for left-handers).
  17. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    i had a 2006 nuvi 340, which at the time was 299..they can be had for about 120 nowdays. It was stolen 2 week's after i bought it, normally I would take it out when i parked for the night, or if in a store for more then 30 mins. Ironically it was lifted, while I was in target for no more then 15 mins. I asked the store manager to review the lot camera's, they saw nothing because my car was parked outside the view of the only 2 cam's on the lot...lol. this was in my honda btw, not prius..broken glass everywhere, they stole my GPS and left the cd's and radio. Most of the cd's are burnt anyway
    I have nothing right now, no real need anyway..i only travel 3-4 times a year out of state..and i know this town like the back of my hand.
    wonder if this guy was the culprint=)
  18. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Y'all northern hemisphere folks that got your brandy-new units
    and have mounted them with little stick-on velcro squares are
    gonna be hurtin' as high summer kicks in and you wind up with
    ridiculous dash temps when parked. You're going to have little
    squares swimming around in lakes of goo. Possibly even if you
    get religion about using a windshield shade.
    I decided that physical hard-mount was the only way...
    And I really like the aftermarket unit feature that you can take
    it OUT of the car and download your whole track of the day's
    road-trippin' for the archives.
    _H*
  19. Boo
    5,051
    488
    97
    Flushing, NY
    Lol. But I'm curious (stupid) enough that I'm going to have to test that theory myself.
  20. joe1347
    joe1347 Active Member
    669
    44
    AZ
    I apologize if someone mentioned this concept, but isn't directly in front of the existing Prius MFD (LCD display) THE obvious place to mount an aftermarket GPS unit. Obviously, while in use, the GPS unit would block the use of the MFD touchscreen. So how about a mount that allows the GPS to slide directly up (or to the side) as needed. I'm envisoning a mount that's the same size as the MFD screen, but with a cutout the same size as the aftermarket GPS unit - including a black plastic bezel that allows the aftermarket to blend into the assembly (and dash) for a clean 'factory' look. Since the screens on some of the latest aftermarket GPS units are reasonably large, the 'factory' look may be even better than one may think.
