Where, How To Adjust Std. Headlights on 05 Prius
Discussion in 'Gen 2 Prius Main Forum' started by kenkneeb, Jan 27, 2006.
  1. kenkneeb
    kenkneeb Member
    120
    So. Central, Pacific SouthWest Oregon
    Where, How To Adjust Std. Headlights on 05 Prius as they were aligned too high from factory and I want to reset them myself. I've looked everywhere under the hood and on this board too, and I can't find a reference for adjusting/realigning for the 05. The info on the 04 didn't seem to pertain as it mentioned removing the radiator support and adjusting a philips screw, however the headlights are quite far away from the radiator support.
    Any help, pictures, movies, guided tours, would be greatly appreciated.
    Tanks a mucho.
    KennyOregon
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    quick question is there an oblong kidney bean shaped plastic snap in cover on the drivers side of the black rad support cover on the 2k5's?
  3. kenkneeb
    kenkneeb Member
    120
    Hey Frank:
    Nope no Kidney bean shaped plastic snap in the cover of the driver's side read support cover.
    Such a mystery! Any other thoughts?
    Thnks again,
    Ken
  4. Frank Hudon
    4,147
    sorry then that has changed on the 2k6 also.
  5. Frank Hudon
    4,147
    Brookings ?
  6. kenkneeb
    kenkneeb Member
    120
    Talent, near Ashland, South Central Oregon (I5 Corridor).
    Any other headlight thoughts.
    ken
  7. Tideland Prius
    16,445
    The owner's manual states how to adjust the headlight aim. You'll need a screwdriver. It's near the pages where they tell you how to remove the bulbs.
  8. kenkneeb
    kenkneeb Member
    120
    I have an 05, there's no info in the 05 user manual.
    Ken
  9. Tideland Prius
    16,445
    hmm, interesting. I have the 04 manual on my home computer but I won't be home til later this evening. Perhaps someone else with an 04 manual can give you the exact location. Either that or they removed that feature for 05.
  10. kenkneeb
    kenkneeb Member
    120
    thanks, I'll double check the manual, as maybe they hid the info somewhere els.
    ken
  11. Frank Hudon
    4,147
    tideland when you put in your silver stars did you notice the little star wheel? Also Ken you'll need a #2 phillips about 10" long to get down in there. Your looking for a little U shaped slot and in the depths of it you'll see a starwheel, the screw driver just sit's in the U and when you push it in to engage the star wheel it keeps the screw driver from coming out of engagement. Dave in Olympia has the little snap in cover and the wheel is behind it and down behind the headlight.
  12. kenkneeb
    kenkneeb Member
    120
    I don't see any star wheels, but I can take picutres of what I do see and email them to you.
    Let me know.
    thnks, ken
  13. Frank Hudon
    4,147
    do it, I'm out for a while but will respond.
  14. KTPhil
    KTPhil Active Member
    1,379
    I remember the kidney cover when I looked at my 2005.
    [attachmentid=1990]
  15. kenkneeb
    kenkneeb Member
    120
    KTPhil, can you point me in the general direction, I have the rad. cover off, but I cannot find a thing that look like the drawing. Is it in the back, near the headlight bulb??? I can't seem to see anything which remotely resembles either the kidney shaped cover or the star wheel. Is this accessed from the top of the engine compartment?
    Thanks, Ken
  16. kenkneeb
    kenkneeb Member
    120
    I just emailed you the photos.
    Thanks, Ken
  17. kenkneeb
    kenkneeb Member
    120
  18. kenkneeb
    kenkneeb Member
    120
    [attachmentid=1997]
  19. Frank Hudon
    4,147
    sorry for the delay. pix of the passenger side adjuster screw/starwheel.
  20. littleprius
    littleprius New Member
    53
    Is proper adjustment of headlights by a Toyota dealer covered during the new vehicle warranty period of a 2005 Prius?
