Where Is The 12V Battery On A Gen5 HEV?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Sep 24, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,204
    2,456
    Paramount CA
    Why is so hard to get that Gen 4 and Gen 5 have active grill shutters?
  2. KCWhitney
    KCWhitney Active Member
    134
    116
    Connecticut
    2025 Prius Plug-in
    I have been trying to avoid dealing the with actual battery clamp in fear of accidentally breaking the connection to the car. But in actually looking more closely at the situation, the battery clamps (both of them) have an easily accessible studs on their tops. This stud is thicker than the hole in the Moco cable, but I have ordered a cable with larger sized lugs, so it should be easy.
    I understand about the ac plug, I will look for a cover for the plug, just to ease my mind.
    Thank you, again. I understand in the end, this has not been worth all of the attention I have put to it. But what else would we we all do, read about tire sizes and storage of spare tires?
    VelvetFoot and Mendel Leisk like this.
  3. Mendel Leisk
    41,447
    That are impossible to scoot a wire by?
  4. Mark Hollis
    Mark Hollis Junior Member
    2023 Prius Prime
    XSE
    Lead-acid batteries release hydrogen gas when they operate. So, when you put the battery inside of the passenger compartment, which is what Toyota does with Prius batteries, you have to vent the gas out of the passenger compartment. So the venting stuff on the battery makes it into a special battery, hence the rather expensive cost.
    I replaced my 12V battery once in my 2005 Prius.I bought it in 2007 and sold it in May, 2025. That’s pretty good battery life. But I would want to check my electrical connections if my battery was dying frequently. Make sure it’s charging, make sure it’s not continually discharging.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,153
    563
    Alberta
    2024 Prius Prime
    XSE
    My Gen 3 had a fairly constant drain of 50 mA, but I learned that if I drove it at least once a week, it wouldn't be dead. I replaced it after about 5 years, because it appeared not to be holding a charge. I was informed it was a special AGM type, and it cost me over $400, despite it being not much larger than a motorcycle battery. I started using a battery maintainer after that, but I found the alligator clips to be unreliable, unless checked and reseated regularly.
  6. Gokhan
    6,204
    2,456
    Paramount CA
    No, not really. These days most lead–acid batteries are center-vented. Here is an AGM battery I installed on my Gen 4 Prius Prime. It works both on Gen 4 and Gen 5 Priuses. Since it is AGM, it is much better than the OEM flooded cell. It is currently only $130.39 and you get another $10 back if you take your core to AutoZone or such.
    AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system | PriusChat
  7. Gokhan
    6,204
    2,456
    Paramount CA
    It looks like they are only on the lower grille. You should be able to pass the cord through the upper grille. I don’t see the need for a permanent quick-connect plug for a car that is practically never driven though. It is only a good opportunity for a bad boy to yank it out and break your grille.
