Where is the beeper speaker located on the dashboard?
Discussion in 'Prime Main Forum (2017-2022)' started by Chris HV, May 3, 2026.
  1. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    Okay, don't laugh but a friend gave me a bunch of doors and lumber that I will use for home improvements.
    Problem is, that stuff does will stick about 2 feet out of my 2018 prime and the darn beeper will harass me all the way. I've done this over a few miles and it's bad enough, but this time it's a 2-hour trip back home!
    I'd like to put something like thick fabric over the beeper speaker but no matter how hard I try, I can't find where the sound comes from on the dashboard... Does anyone know its precise location by any chance ?
  2. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    I’d love to know too, you’re not the only person out there that has used a Prius as a truck:D
    Not going to say any more to avoid attracting attention from the local constabulary, but I will say a flag correctly positioned will at least keep you out of trouble for most parts of the US.
  3. ChapmanF
    19,009
    Are you asking because the hatch won't be fully closed, so the beeper will be beeping about that?
    Why not just push the hatch latch closed? In my gen 3, the latch is where the switch for detecting hatch-open is located. With the latch pushed closed, you shouldn't have the dome light on or the beeper beeping.
    Just remember to push the unlatch button later before going to close the hatch, or it'll make a fearsome bonk when it hits the closed latch.
    PriusCamper and Chris HV like this.
  4. PHEVisthefuture
    83
    25
    Illinois
    Some of us may at times carry things with a door slightly open (bungee cord secured of course) or in other ways that wouldn't "pass muster" lol. Would love to find a way to bypass the beeper.
    Same thing happened the other day just carrying wheels & tires from my track car in the back seat, the beeper said to buckle seat belts, but the seat belts weren't large enough to get around the large sized wheels & fully buckle in.
  5. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    Yes, that's why I'm asking, thanks, and I can't believe that I didn't think of that !
    I will try this as soon as I get a chance, but OTOH I still would like to have the "hush the beeper" option since I too have had many times when it triggers when it should not.
  6. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    As per Chapman, it's better to figure out how convince the sensor that the latch is closed rather than disabling a beeper that can warn you about multiple things, some of which would cause way more problems if you don't hear the beeping.
    Chris HV likes this.
  7. PHEVisthefuture
    83
    25
    Illinois
    Some of the beeps on my Prius are downright incorrect (heavy item in back seat does not = someone back there not buckled up), and others (such as the dreaded "Low Oil Pressure") should be way louder than the typical beeps which are already annoying enough.
    This car, although great, makes it difficult to transition to: (a) a vehicle without back-up sensors/beeping and (b) a vehicle without any sort of rear park assist, which was true for most vehicles pre-2015 without a technology package.
    Whenever I drive someone else's truck, I'm either (a) astonished it only beeps when I get too close to something or (b) go "where are the dang beeps when backing up". Good thing it's not my friend's Ford, which beeps and dings for almost everything, down to the point where you train yourself to ignore them
  8. ChapmanF
    19,009
    I'm not positive the seat-belt beeper will turn out to be the same beeper as the door-ajar beeper. It certainly seems economical to have one little piezo speaker somewhere and have it make multiple sounds—or even just use the audio speakers, what a thought—and maybe it is that way in gen 4, but my experience in older gens is of a plethora of beepers.
  9. Chris HV
    Chris HV Member
    67
    36
    East Coast, USA
    2018 Prius Prime
    I do not wish to disable it, but simply to muffle the sound to a bearable level.
  10. PriusCamper
    13,451
    5,430
    In a perfect world you'd have full control of how you want those beeps to sound and when you don't want them to make noise, kind of like a ringtone on your phone. But sadly when it comes to computer code Toyota is about 20 years behind. However, there's some settings in Toyota Techstream or via Autel AP200 device that allows you to lower the volume? Or just turn beeps on an off, but you do so at your own risk.
    For example, I learned how to turn off the reverse beep on my Gen2. Then one time I backed up a little at a red light and forgot I was in reverse and when I went to accelerate I went the wrong way and was grateful I hit the brakes fast enough to not hit the car behind me... That was when I decided I'd rather have the reverse beep, but instead of a beep I'd rather have a beautiful women's voice saying: "Don't you ever back away from me."
  11. PHEVisthefuture
    83
    25
    Illinois
    :D
    I could use a less nagging beep on mine too. Seems like it chimes every 1/2 second when in reverse & the woman's voice would be just icing on the cake.
  12. PriusCamper
    13,451
    5,430
    It'd be loads of fun if we could get it to speak in familiar voices... I mean who wouldn't want to hear their mother-in-law saying "be careful when going in reverse" over and over and over again every time you shifted into reverse? :)
  13. ChapmanF
    19,009
