Where is the diagnostics port located?
Discussion in 'Gen 4 Prius Main Forum' started by PriusRos, Oct 10, 2019.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I found out that I can do the Maryland emissions test and save $4 using a self-service kiosk so watched a video on line to find out how to do this. However, I cannot find the port where you plug in the emissions meter! I saw some previous posts asking this question and the answer was it is to the left of the steering wheel and somewhere near the gas cap lever. One reply was "Oh, it was right in front of my nose!" Is this something that can be seen from a normal position because I have looked all around and do not see it? Is there a cover? I can feel something when I put my hand underneath the dash, to the right the gas cap lever and towards the back. Is that it? I am not able to see it unless I contort myself into an impossible position on the floor.
    I'd much appreciate it if someone would describe the location and post a picture because I have no idea what to look for.
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Stick your head right into the driver's footwell, until your head touches the pedals. Rotate your head like an owl 180 degrees to look up towards the bottom of the plastic panel near to where the driver's knee would be, and you should see it, just tucked behind that panel, pointing towards the floor. It looks like an old SCART TV socket.
    alanclarkeau, krmcg and Mendel Leisk like this.
  3. PriusRos
    1,973
    218
    Rockville, MD
    :eek: Thanks. So yeah, totally visible right in front of my nose as long as my head is on the floor under the panel facing up, right?
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Is this OBDII socket you are talking about?
  5. PriusRos
    1,973
    218
    Rockville, MD
    I don't know but I assume there is only one socket where you can plug in a diagnostic monitor.
    krmcg likes this.
  6. The Professor
    598
    809
    UK
    Excel
    Correct! :D
    alanclarkeau and PriusRos like this.
  7. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    It's easy to get confused. Gen 4 it's to the left of the steering column (above the parking brake pedal). I believe to a little to the right of that on the Gen 3 Prius (closer to the steering column). The port on the 2016 Prius (gen 4) is shown at the beginning of the video below (0:21 in the video)
    #7 ice9, Oct 10, 2019
    PriusRos likes this.
  8. The Professor
    598
    809
    UK
    Excel
    ...but only in LHD cars. On RHD cars it's above the accelerator.
    ice9 and alanclarkeau like this.
  9. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Thanx. I believe I was wrong about the Gen 3 Prius too (now corrected). On Gen 3 vehicles I believe it's to the left of the steering column (not right) but closer to the brake, not the parking break.
  10. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    WAIT! You can do the emissions test yourself? That would be really helpful here in California where they pop the hood of the car, look at, close the hood and charge you $50 or more.
  11. PriusRos
    1,973
    218
    Rockville, MD
    Thanks. I'm not sure I'll be able to get down there to plug in the scanner.
  12. PriusRos
    1,973
    218
    Rockville, MD
    50 bucks??!! In Maryland, the emissions test (every two years) costs $14, or $10 at the do-it-yourself kiosk. This is the first time I saw this option. When I got the notice, it said it costs less at the 24-hour kiosk, but didn't explain what it was. I thought it was just a different payment option. But when I went to the website, I saw that you can actually do the test yourself.
  13. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    The first time it's difficult, because, as you say, you have "to get down there" with a flashlight to see what you're doing. After that, however, after you become familiar with how the dongle is oriented to plug in, you can do seated in the driver seat. The dongle is keyed. If you get it wrong the first time, just flip it around and try it again.
    PriusRos and jerrymildred like this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Here in the UK the Prius is exempt from emission tests. :p
    alanclarkeau and jerrymildred like this.
  15. PriusRos
    1,973
    218
    Rockville, MD
    It used to be exempt in Maryland too.
