Where is the harddisk?
Discussion in 'Gen 2 Prius Audio and Electronics' started by bugzee, Dec 14, 2015.
Tags:
  1. bugzee
    bugzee New Member
    Sri lanka
    I've got a Prius anniversary model Japanese language. I want to know where the haddisk is located? I'm curious to see what it has by connecting to my desktop/laptop.
    Thanks.
  2. arescec
    arescec Active Member
    238
    105
    Croatia
    As far as I know it's a part of head unit.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    If you have nav, the drive is under the drivers seat, it would be a hard-disk.
  4. bugzee
    bugzee New Member
    Sri lanka
    So I'll have to remove the NAV unit and open that to access the harddisk?
    In my case the NAV unit is under the passengers seat.
  5. arescec
    238
    105
    Croatia
    Sorry, didn't see that this is under Gen 2 :/
  6. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    If your Prius is a 2007 "gen2" it does not have a hard disc. The satnav works from a DVD player under the passengers seat.
    John
    Data Daedalus likes this.
  7. bugzee
    bugzee New Member
    Sri lanka
    I'll upload a photo of the NAV system during the weekend, also it has no DVD slot. It has something like a USB port.
  8. bugzee
    bugzee New Member
    Sri lanka
    I've uploaded the images. See the Back images, it has no DVD slot just something like a USB.
  9. bisco
    51,140
    what about in the front?
  10. bugzee
    bugzee New Member
    Sri lanka
    What front? No DVD slot there either. Just want to know if the hard-disk is in here..
  11. bisco
    51,140
    i don't think so, but not sure. i thought it was a regular dyd player with slot for dvd updates.
    but i'm thinking about gps. are you talking about general hard disk for all computer operations?
  12. bugzee
    bugzee New Member
    Sri lanka
    I don't know about a general harddisk, because I've seen models without harddisks. The songs are recorded to a harddisk in my car (there is a button to record on the MFD), I'm trying to find out where the actual harddisk is..
  13. Britprius
    5,194
    1,918
    According to the Toyota part number shown in your picture (86841- 47071)of the navigation unit. That is the standard DVD navigation player.
    Further the socket shown is not a USB port. A standard USB port has 5 pins.
    John
  14. bugzee
    bugzee New Member
    Sri lanka
    Hi john,
    Thanks for the infor, but then how do we update the Navigation, as you can see there is no DVD slot.
    Anyway reverting back to my original question, is the harddisk inside this unit?
    Also John, a standard USB port has 4 pins, 2 for data and 2 for power.
  15. Britprius
    5,194
    1,918
    I have not got the manual for the navigation unit at hand at the moment, "I am away from home" but from memory there is a sliding lid on the other side of the unit to the connectors with an eject button, and DVD slot under the lid.
    When I return home I will check for more accurate details. The DVD contains all the map, and voice information with different DVD's for different counties.
    John
  16. bisco
    51,140
    you can record music on your mfd? never heard of that before. this is getting more interesting by the post!
  17. Britprius
    5,194
    1,918
    There is a record button in the menu for checking the volume of voice commands received by the voice recognition system. You can alter the volume of the received command through the microphone.
    John
  18. bugzee
    bugzee New Member
    Sri lanka
    you can see the "REC" button in 1.jpg. Once you see the song list on the CD you can see what songs are recorded to the harddisk (2.jpg - you can see a small yellow icon with 'HDD' top left of the song name). In 3.jpg you can see the songs in the harddisk.
    So, where is the harddisk physically located now?
      File size:
      97.8 KB
      File size:
      109.4 KB
      File size:
      116.2 KB
  19. bisco
    51,140
    amazing, never heard of such a thing. could this be japanese version only?
  20. Britprius
    5,194
    1,918
    You are correct on the number of wires used, but on the flat USB plugs, and sockets there are 5 pins one of witch is not used. This does not apply to the "D" shaped plugs where there are 4 pins.
    John
    As "Bisco" suggest this must be a Japanese domestic market version only as all known gen2 Prius as far as I know in Europe, and the US do not have a hard disc fitted up to 2009. The gen3 Prius from 2009 in Europe, and 2010 in the US does have a hard disc. You list your Prius as a 2007 version.
    John.
