Where is the USB port?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by paulsha911, Feb 25, 2014.
  1. paulsha911
    paulsha911 Junior Member
    26
    Hi:
    I searched the forum and can't find this answer.
    Where is the USB port in the Prius Plug-in? It's not in the places stated in the manual (ie. glove box or below the deck).
    Thanks.
    Paul
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    in the center console, in the front of the console inside.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    [Edit: this is wrong]
  4. paulsha911
    26
    On that panel, I have two heated seat controls and no USB port. :(
  5. markabele
    5,084
    1,782
    Nebraska
  6. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Must be different in the wagon, which is what Jimbo lists as his vehicle.
  7. paulsha911
    26
    Ah yeah, sorry about the two threads... my browser hung after I hit submit, and then two threads was created. How do I delete or merge?
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There are two trim levels for the PHV, apparently the USB is better hidden in the fancy trim.
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There is a report button, you may report yourself
  10. rogerv
    1,639
    317
    Jimbo,
    The picture shown is of an aftermarket DIY install by rosenberger31 in his 2010 Prius III. Not sure why you chose to use it, as it is misleading.
    Add a USB Power Outlet in Your Car
  11. bisco
    52,804
    the pip base also has heated seat controls in that panel. usb is inside the center console, bottom front.
    JimboPalmer likes this.
  12. rogerv
    1,639
    317
    I checked with a friend who has the Advanced trim, and his is also in the console box. Don't know where Jimbo is coming from.:confused: The OP didn't specify which trim he has, but the answer is the same.
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am wrong
    rogerv likes this.
  14. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    I thought that USB port in the photo above looked a little busted...
  15. rogerv
    1,639
    317
    Thanks, Jimbo. BTW, should someone want to have a USB plug in the lower tray area, I have seen 12v plugs with a USB port, so you can convert the outlet that the PiP has between the seat heater switches.
    12 volt to usb plug | eBay
    The one in the console box is indeed difficult to find, so I rarely unplug my iPod cord from it. There is the added benefit of keeping everything out of sight under the armrest.;)
  16. CharlesH
    2,798
    1,166
    Roseville, CA
    Same for the charger outlet in the armrest. I just leave the charger plugged in, and keep the end sticking out through the grove between the lid and the base so I can just pop on the charger if I need it.
    markabele likes this.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
  18. rogerv
    1,639
    317
    Well, in the picture it is hard to tell, but the OP said this in the body of his post:
    "Where is the USB port in the Prius Plug-in?" I think that's what we all have been going by.
  19. paulsha911
    26
    Hi All:
    Sorry for the late reply. Had been traveling.
    It's a 2014 Plug-in.
    I did find the USB port. It's inside the center console box, on the front wall next to the AUX audio jack.
    Thanks.
    Paul
  20. paulsha911
    26
    Thanks to priuskitty, I found it. (In the front wall inside the center armrest console.)
    It's indeed hard to plug-in. I also don't like my long USB drive sticking out. Am going to buy one of those small ones so I don't break it if I accidentally bump it hard when reaching in for stuff...
    Paul
