Where is the valve to drain engine coolant?
Discussion in 'Generation 1 Prius Discussion' started by Jesse Elledge, Sep 13, 2020.
  1. Jesse Elledge
    Jesse Elledge Junior Member
    34
    Barstow, CA
    2003 Prius
    I
    Can’t seem to find it anywhere. Thanks in advance for the help. Just trying to do a flush.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    I believe the Gen 1 radiator has a drain valve at the bottom corner opposite of where the fill neck is located. I believe the photo below is a Gen 1. The white petcock at the bottom corner should be a drain.
  3. Jesse Elledge
    34
    Barstow, CA
    2003 Prius
    I
    Thanks a lot.
