Where Is Windshield Scuttle Drain?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusII&C, Apr 14, 2021.
  1. PriusII&C
    PriusII&C Active Member
    426
    144
    San Jose, California
    Just finished installing EGR/TB/IM. Tried to check front wipers. Worked fine except that all the windshield washer fluid eventually dripped right behind the front wheel on the passenger side. Is this normal?
    I tried to locate the windshield scuttle drain. Opened the hood and saw a wet line at the very back of the firewall behind the engine on the passenger side. Should the water also drips to the driver side? Or did I install something improperly?
    Thanks.
