Where to buy a JBL head unit?
Discussion in 'Gen 4 Prius Audio and Electronics' started by timdafweak, Sep 20, 2016.
  1. timdafweak
    timdafweak Member
    35
    46
    Tampa
    2018 Prius
    Just out of curiosity, for those of us with the lower trim with the stock Head Unit, it SHOULD be possible to replace it with a JBL head unit from the higher trims, right? If so, where would one look even... I tried eBay, but it seems my search queries are wrong, or there is no-one selling JBL Prius Head Units yet.
    Does anyone know?
  2. ChapmanF
    15,614
    The JBL systems in the higher trims are generally different in that there is a separate JBL amp mounted elsewhere in the car (not sure exactly where in the Gen 4, it's under the passenger seat in a US Gen 3). You would need to add the amp as well as the JBL headunit, and you would need to make sure the wire harness from the headunit to amp exists, or supply that too. I think the JBL amps have outputs for more speakers than the non-JBL headunits have, though you could maybe leave them unconnected if you weren't adding the missing speakers too.
    -Chap
