Where to buy front seal for sunroof deflector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vallesj, Sep 29, 2023.
  1. vallesj
    vallesj Junior Member
    98
    The seal is broken and is creating excessive noise at highway speed. Where can I buy the replacement? Or is there something else recommended to replace it?
    51,148
    dealer?
  3. PriusCamper
    PriusCamper Senior Member
    12,061
    4,894
    Pacific Northwest, USA
    Least expensive way is to pull one off a wrecked Prius... And if you're skilled enough to do the install, standard weatherstripping like this would work: https://www.ebay.com/itm/195366721724
  4. PriusCamper
    12,061
    4,894
    They'd probably tell you that you have to replace the entire sunroof for $3K, but you'd be better off financing a new car on their lot that's not a hybrid because there's a waiting list for hybrids.
  5. vallesj
    98
    I prefer not that expensive... online options are much cheaper...
  6. vallesj
    98
    That better describe why not going to dealer.
    PriusCamper likes this.
  7. bisco
    51,148
    There are online parts sources like camelback Toyota
  8. vallesj
    98
    I had replaced already by myself the deflector assembly already, since it cost $800+ just the part. The ebay stuff, I had already considered it, but if someone already did it and worked fine I would be glad to hear the lessons learned.
  9. vallesj
    98
    Have not found the part number from the diagrams..
  10. bisco
    51,148
    Maybe ask a dealer for the part number and price, then see what you can find online
  11. vallesj
    98
    Dealer is not sure about what part number is... they indicated that on the computer it is likely the 75533-47050 but they are not sure...
    I found the part with a picture on the following ebay post:
    https://www.ebay.com/itm/225780763215?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ueEBmwGiSWi&sssrc=2047675&ssuid=&widget_ver=artemis&media=COPY
    but it is not clear if that is the correct part.
  12. vallesj
    98
    Still not getting the part, the one mentioned by dealer is the normal windshield seal. I took off the damaged part, and it's like F shaped rubber.. tried the h shaped part from Amazon but didn't work. "AUTOXBERT 4M/13Ft Car Weather Stripping H Type Rubber Sealing Strip Trim Cover Automotive Front Windshield Sealing Strip Trim for Car Front Rear Windshield Sunroof Weatherstrip"
    I just placed 3 lines of black vinyl tape (electrical tape) to cover that section.
  13. bisco
    51,148
    idk if they can help, but might be worth calling toyota customer service
  14. vallesj
    98
    Just got a response from them.. they basically directed me back with the dealer parts department.
  15. Lesmir300
    Lesmir300 New Member
    Phoenix
    I'm looking for exactly the same trim piece, dealer guy had no idea which part it is, tried selling me trim molding under the sunroof, side molding, windshield molding, they truly have no idea how to get this only trim piece, between top windshield and deflector,
