Where to get power for accessories?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by IwasBirchyFirst, Sep 17, 2025.
  1. IwasBirchyFirst
    IwasBirchyFirst Junior Member
    27
    Dallas, TX
    I need to add some extra lighting and wonder what the options are for getting a fused source of 12v DC.
    I don't want to use the lighter ports, they are in use for other things. I presume that leaves under the dash, as I don't see anything under the hood.
  2. ChapmanF
    18,971
    I'd usually start by deciding when I want it to have 12 volts (all the time? When the car is in ACC? IG ON?), and where I want it (in the cabin? out under the hood?) and then start looking in the wiring diagram:
    Toyota Service Information and Where To Find It | PriusChat
    Sometimes you even find your trim has a fuse slot already present that isn't used, and the inner-circuit diagram shows you which connector terminal it comes out on.
    Of course, how much current you want also matters. It wouldn't be a good idea to use a larger ampacity fuse in a slot that was intended for a smaller.
  3. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    What type of lighting? Depending on how much amperage you're going to need, there are likely
    fuses that aren't being used you can tap into. Like the heated seats? If you don't have heated
    seats, you can use that spot.
    PriusCamper likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    More lighting for what? How many watts are the lights? The wiring you would do for exterior lighting is way different than what you'd do for interior lighting
