Where to put hole in center console?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Wraiththe, Nov 30, 2018.
  1. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    2010 Prius. I would like to drill/ cut a hole in the center console so I can plug a USB cable into the aux port, then route it underneath the box and out to the passenger side... so I can route it up the seat to the headrest.
    My concerns are where to drill the hole and are there wires in the way? Is it hard to remove the console or does it require removing the rest of the front as well?
  2. PriusCamper
    PriusCamper Senior Member
    13,398
    5,411
    Pacific Northwest, USA
    If you have a local wrecking yard where you can pull your own parts and they have a car the same as yours, you can practice taking it apart without worrying about ruining your car... But in general removing as much of the console as possible before you drill will give you the assurance you need to know you won't be drilling through any wires or anything.
    James Powers and Burna J like this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Tuck it under the panels
