Where to put my iPhone
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mikenancy1, Mar 9, 2013.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    Has anyone come up with a good place to put an iPhone so it is easily visible to the driver? I like to use Waze for my GPS, rather than the Toyota version, so I need to have it where I can see it. I don't want to cover the heating vent with one of the clip holders, and I don't have any other great ideas that wouldn't involve sticking something permanent to the dash.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  3. Mendel Leisk
    42,345
    We mount a Garmin (about the same dimensions) with it's suction cup mount in that little triangle window to left of driver. Maybe there's something like that available for IPhone?
  4. mikenancy1
    105
    Geneva, IL
    Good thought. I'll try that.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Around here street people (ie Bums) see the mounts (or the ring left when you dismount them) and break into the car looking for the GPS that you put in the glove box.
  6. Firephoenix1980
    Firephoenix1980 Junior Member
    16
    Fort Lauderdale, Florida
    zhutton and mnml like this.
  7. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I keep mine in the front cupholder and let MapQuest turn-by-turn talk to me. I keep a mental picture of the route in my mind so I seldom need to look at the screen.
    BCP likes this.
  8. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    "Where to put my iPhone?"
    In the trash... Android guy here. :D
    SalixIncendium likes this.
  9. eyespii
    eyespii Junior Member
    48
    2013 Prius Plug-in
    I have this Mountek mount, and can attest to how sturdy and solid the thing feels. Super easy to install, and completely removable without any permanent damage to the vehicle. Also love how it's adjustable too. Do note that when installing it in the PiP however, a small part of the mount will obscure the top part of the LCD screen. For that reason alone, I actually don't use mine much any more. I've used ProClip mounts before, and I'm thinking about picking one up.
    ChipL likes this.
  10. EOB
    EOB New Member
    I got a cupholder phone holder for my galaxy S3 in my 2010 P3 from amazon. I put in in the holder that's under the sliding armrest (the rearward cupholder). I'm really tall so have my seat all the way back (I'm getting seat extenders installed) and have the seat-back tilted back. This means that I can rest my arm on the slid-back center console armrest and operate my touch screen without extending my arm. The cupholder phone holder is really sturdy - but the actual cup holder under the armrest is removeable, so I need to lock the actual cupholder down somehow to make the phone really locked in so I can push the physical buttons on the side of the phone without the holder wobbling.
    Plugged phone into the cig lighter in the center console and then also hooked up the phone earphone jack to the aux plug also in the center console and am streaming iheart radio (which I like better than paying for xm or listening to ads on FM). The aux setup I just connected, and found that the phone thinks an earbud/mic's installed, so the bluetooth speaker/mic is over ridden. I'm guessing there might be a setting to prioritize bluetooth. The 2010 P3 doesn't appear to stream audio via BT, just phone.
    hope this helps ?
  11. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Like what I saw.... But the LCD thing, would that be the same issue for any G3 Prius?
  12. eyespii
    48
    2013 Prius Plug-in
    I believe so, yes. However, I've never tried it personally.
  13. RaZa
    RaZa Member
    480
    93
    I took the suction cup part of a garmin mount off and filled the bottom up with 7 minute epoxy. Just as it was about to harden i put saran wrap on the area of the center console where it was going and pressed it down onto that so it would custom fit to the curve. Then I used 3m double sided permanent tape to hold it in place. It's amazing how strong that stuff really is. To me this was the perfect iphone/ipod mounting area.
    The cradle is a DICE iphone mount. It rocks and it can fit any apple device on it. I also used 3m doubled sided take to stick the socket part of the garmin mount to the back of the cradle. Just needed to dremel off the curved bits that normally hold a gps.
  14. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
  15. eyespii
    48
    2013 Prius Plug-in
    Here you go - just snapped this on my 2013 prius plug in.
  16. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
  17. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    My pocket. Bluetooth rules. I use the tethering hotspot option from AT&T. All the phone and Entunes functions work from the Prius touch screen.
  18. Sfcyclist
    1,621
    376
    SF, CA
    I stream Pandora a lot so need to connect through Entunes.. have a cradle/spot allocated for it would be great.
  19. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I bought the universal mount so I could watch gauges on Dashcommand. It works very well for that and is quite rigid. Mounting to the A-pillar window keeps it out of the way yet in reach.
  20. Sfcyclist
    1,621
    376
    SF, CA
    thanks.. I love the idea but it does block the navi screen as suspected. I'll post the $2 one I found shortly!
