where to put small blind spot mirrors?
Discussion in 'Newbie Forum' started by Baldbubba, Jul 19, 2013.
  1. Baldbubba
    Baldbubba Member
    142
    27
    in PRIUS down by the river
    I have seen all different places to put the blind spot mirrors on the regular side Mirrors. Top outside or top inside closest to the car, or bottom outside or bottom inside Closest to the car. Is The placement the same for both sides of the car? I love this car but it certainly has a huge blind spot area on both sides of the car
  2. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    I have mine lower left side, Drivers Side and Lower Right on the other side.
    Hope this helps
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It depends how you have your mirrors setup. If conventional, place them as mentioned above.
    If you have your side mirrors adjusted to eliminate the blindspots on either side, as I do, then use the small stick on convex mirrors only as an aid to see the stall markings when reversing into parking stalls. Then place them on the inside lower corners so you can see the side of your car and the markings on the ground.
    SCH-I535
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I use the cheap 3" round spots. I place them as far to the outside and as high up as possible. That leaves an inch or so under the spot where you can still use the main mirror. And it allows a full view of the side of the car.
    One tip: be careful not squeeze the spot mirror too far to the outside, cause it will block the motion of the power mirror when it tries to pivot out. Keep it inside the outer edge of the mirror. Use a small loop of scotch tape to temp stick the spot and see if it checks out, then mark the spot with more tape, then and only then peel the backing off the spot.
    kaynin and CarStalker like this.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I tried the outside tops on my car and outside bottoms on my wife's. I liked the bottoms better so moved mine.
    PLSPUSH likes this.
  6. xliderider
    8,140
    3,277
    Honolulu, HI
    Yes, it leaves more of the main mirror available IMO when placed on the bottom outside corner.
    SCH-I535
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have bought, installed and removed so many blind spot mirrors for this vehicle it's ridiculous. It's almost a subconscious hobby. If I pass an automotive parts store I haven't been in, I stop and check what they offer as far as blind spot mirrors.
    It's all okay, but I think The Prius mirrors are a little on the small size. Right now I'm going with the standard round 2 inch mirrors, and I place them on the outside lower edge.
    It's been a oddly difficult battle to find mirrors and positioning I like on The Prius. But I mostly attribute it to the mirrors themselves being a little oddly shaped as well as I think a little small.
    RCO likes this.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I found some 2" mirrors at Advanced Auto that were adjustable inside their housing. After putting them on outside bottom it gave me the ability to play around until I was able to find an optimum setting.
    RCO likes this.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    I like those adjustable mirrors, except for the fact that they are easily knocked out of adjustment when washing/drying the car and other people.
    SCH-I535
  10. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Looks like we have a consensus: put them on the mirror somewhere. :confused:
    RHennick and RCO like this.
  11. Baldbubba
    Baldbubba Member
    142
    27
    At least we all agree on the mirror,,, This looks like finding the prettiest girl matter opinions!
  12. DomoDriver
    DomoDriver Junior Member
    28
    New Mexico
    How does washing/drying other people affect the mirrors? ;)
    Sorry, xliderider, I couldn't resist...
    AnEwoksIntoABar and ftl like this.
  13. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Problem is that they REALLY stick and its a bear to remove the goo.
    Which is why I suggest using some scotch tape to temp place them and see if you like.
  14. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Put to the outside and low. You'll get used to them in no time.
    Just dont go too small.
  15. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Inside on top is a dead area, where no vehicle will ever be seen anyway... except perhaps a flying Delorean. That's where I've been putting mine. Works great.
    Another suggestion is to get the tinted kind. Blue works really well. I got my set at PepBoys for $8.
  16. Mr Incredible
    955
    506
    Neb
    Must depend on how tall a person is. I use low and out for all our cars, and on mirrors large enough to have open areas I use that upper portion.
    On the C I have 3 inch convex mirrors. There's no extra space above the stick on.
  17. GBC_Texas_Prius
    218
    38
    gbc texas
    I second high inside. Initially I put them on the bottom part of the mirrors and didn't like them there.
    The mirrors are a touch too small. One of the few negatives I have about the car. I think the mirrors could be designed to be further out without a major aerodynamic penalty if they gave a skinny arm and a narrow shape.
  18. Baldbubba
    Baldbubba Member
    142
    27
    I don't think there is a right or wrong place to have that we can put them right square in the middle?..
  19. Lance Coon
    Lance Coon Junior Member
    Lohrville, Iowa
    I can't post a link.. but the best advise I got about car mirrors was from car talk.. google car talk mirror adjustment
  20. Uncle Lew
    Uncle Lew New Member
    Milford DE
    2014 Prius c
    Great point regarding the use of some temporary tape to make sure that the mirror will still adjust fully with the added blind spot mirror. ThNks
