Where to start with death rattle?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Carpetfuzz, Sep 15, 2025.
  1. Carpetfuzz
    Carpetfuzz New Member
    Ohio
    2016 Prius v wagon
    my 2016 Prius v has "death rattled" twice now, a few days apart, and both happened after sitting for about a day, a few days apart, and hasn't happened since.
    The car has 142,000 miles.
    I am taking it into the dealer to get it looked at and diagnosed in 2 days. I am going to try to have them check the head gasket for leaks, and check the EGR system. I expect the EGR to be clogged, as it has probably never been serviced.
    My understanding with how the EGR, death rattle, and head gasket issues are connected is that the EGR clogs from normal use, which can cause the rattle on it's own right? then temperature fluctuations cause the head gasket to fail at an accelerated rate, which begins the coolant leaking, then its the same rattle but far more consistent because of the pressurized coolant leaking while the car cools down after parking?
    I want to know, what should I do next? My plan is:
    - if the head gasket is bad already, I get it done right then and there at the dealer, expensive but necessary at that point.
    - if the head gasket is not bad, I clean and / or replace the EGR stuff on my own, and hope that the head gasket doesn't fail in the future, but if it does then so be it.
    I think I have a pretty good idea of how it all works, but not sure if im spot on with my understanding of the issue. I guess my big question is, does the EGR cause the head gasket to fail? can I likely save the head gasket if I don't let the EGR get too bad?
  2. ChapmanF
    19,060
    One thing worth remembering is that what's often called "the death rattle" is the sound made in the transmission when the engine crankshaft rotation isn't steady enough to stay matched to the MGs, and the slight lash in the meshed gears gets clanked back and forth. It's a very alarming sound, which results whenever the engine runs roughly / misfires for any reason; the two possible reasons you've been focusing on so far are two out of many. Not all of the possible causes are major issues, so the term "death rattle" is kind of overwrought.
    There are a few causes that are kind of well known. If there is just a brief rattle on first start, after sitting cold for a while, and the last use of the car was short enough the engine didn't fully warm up, then the cause of the rattle was probably condensed water collecting in small intake manifold passages. That particular problem has been known a long time: the first reports were from people driving the earliest "model year 2010" cars in fall 2009. The answer to that issue mostly boils down to: avoid those short uses where the engine doesn't warm up.
    If there is misfiring only at mid-loads (not idle and not full throttle). there is probably clogging of the small EGR passages in the intake manifold. Only at mid-loads is EGR used. and so if there is misfiring only at the times EGR is used, probably the small passages are delivering it unevenly to the four ports.
    If there is misfiring at idle, when there isn't supposed to be any EGR, one possibility could be an EGR valve that's not completely closing, but that would have to be checked along with many other usual suspects (plugs, etc.) for misfiring at idle.
    The behavior usually associated with a head gasket problem will be a misfire right at first start that clears up fairly quickly, but happens consistently (not just occasionally after short non-warmup drives, like the condensed-water business).
    Brian1954 and Carpetfuzz like this.
  3. Carpetfuzz
    Ohio
    2016 Prius v wagon
    Interesting, so I guess it is possible that it was just the water condensation both times, but I don't remember how I drove it before each of those occurrences. When it has happened, it rattled for about 5 seconds right when I started the car, then stopped rattling and ran fine, so it was idling. It has never rattled under any load of any kind. So based on this, it seems like either it was condensation, or my EGR valve is beginning to fail.
    When the head gasket fails, does it start failing slowly? Or will it, one day, just start rattling every time I start the car?
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,144
    6,986
    Texas Hill Country
    This is typical of an early hg leak and will repeat occasionally as it slowly progresses over weeks or months. An egr clogging is more likely to cause stumbling and stalls if the egr valve is stuck open and do nothing if the system is clogged shut. In fact one of the best ways to eliminate the egr is to completely block egr flow.
    The good news is a 2016v has updated pistons and rings and is not as likely to have a leaking hg.
    Carpetfuzz likes this.
  5. Mendel Leisk
    42,379
    Has the EGR system ever been cleaned?
    From your previous, it hasn't. I'd check the cylinders with a borescope, looking for coolant.
    #5 Mendel Leisk, Sep 16, 2025
  6. ETC(SS)
    7,579
    ...after checking you coolant level.
    Remember also that the only definitive test for a head gasket leak is with a leak-down test.
    You can have this done for a few hundred dollars at a decent independent shop.
    You can do it YOURSELF for free in a few hours if you live near a parts shoppe that loans out the tools.
    If you ask your dealer to find a head gasket leak?
    They probably WILL.
    Good Luck!
    (You're apt to NEED it!)
    #6 ETC(SS), Sep 16, 2025
  7. ChapmanF
    19,060
    Well, if a borescope shows you coolant dripping into the cylinder from the head joint, that's kind of definitive.
  8. rjparker
    11,144
    6,986
    Texas Hill Country
    I don't believe the dealer will blindly diagnose a hg. If it's a cylinder miss caused by a plug, coil or injector they can diagnose that quickly and repair. Most dealers know a hg diagnosis is big as they always suggest a rebuild or a trade - which is sure to upset the customer. They want to get it right the first time with no mistaken repairs.
    Most early gen3 head gasket leaks pass leak down and combustion gas tests.
    Conventional powertrains don't have dampers to rattle for 5 seconds and do not generate driver complaints at this stage.
    The dealer has seen this many times.
    Car Care Nut HG Borescope at 660s
  9. Carpetfuzz
    Ohio
    2016 Prius v wagon
    Hi everyone, thanks for the info. Getting it checked at the dealer tomorrow. If they aren't conclusive about the HG, I guess I will buy a borescope and start the diagnosing process on my own. I will not, however, be replacing the HG on my own, that sounds like a nightmare.
