Where'd my turn-by-turn guidance go?
Discussion in 'Prius c Audio and Electronics' started by Ghoti, Jun 24, 2013.
  1. Ghoti
    Ghoti Member
    101
    Arizona
    All of a sudden, the navigation system in my Prius c is no longer giving me turn-by-turn guidance. It will, when I set a route, give me directions, once, and will then remain silent unless I press the onscreen volume button, or use the 'Repeat directions' voice command.
    I've looked through all the options screens several times, but don't see anything that seems connected to turning voice guidance on or off.
    How can I get this working again?
  2. ztanos
    ztanos All-around Geek!
    3,331
    1,138
    40
    Cumming, Georgia
    Hey Fish... did the volume somehow get turned down in the default and it keeps returning to that? Check it by going to setup volume and it's one of the menus... it doesn't sound like this, but it never hurts to check.
  3. PriusC-illa
    PriusC-illa Member
    153
    63
    NYC/NJ
    Do you have Entune 2.2? Mine was doing weird stuff and the update seemed to fix most of the issues.
  4. wmo168
    wmo168 Member
    239
    48
    South Florida
    v2.3 is latest which can only be done at dealership
  5. Ghoti
    Ghoti Member
    101
    Arizona
    I have the update done via the USB flash drive which someone posted on these fora a while ago; I understand there is a newer one out through TSB 0051-13 at dealers. Maybe that'll fix it?
  6. Ghoti
    Ghoti Member
    101
    Arizona
    That's one of the first things I checked. It just makes the volume when I use 'Repeat directions' louder, but does not bring back turn-by-turn directions.
    ztanos likes this.
  7. PriusC-illa
    PriusC-illa Member
    153
    63
    NYC/NJ
    I think it should. Mine runs a lot better now, although slow at startup. It might be due to some setting though. The salesman set everything up for me when i picked up my car, then he decided to leave the dealership so I don't know what my settings were before the update.
  8. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    PriusC-illa likes this.
  9. ztanos
    3,331
    1,138
    40
    Cumming, Georgia
    There is a TSB to update to 2.3.
  10. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    What's the TSB number for 2.3?
  11. ztanos
    3,331
    1,138
    40
    Cumming, Georgia
    Sorry, you're right. 2.2... been playing with too many google phone roms today... :(
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    OK, no problem - just wanted to be sure Toyota didn't sneak in another update! :)
    ztanos and PriusC-illa like this.
  13. Ghoti
    Ghoti Member
    101
    Arizona
    So I got the 2.2 update today at my dealer, and this problem, as well as some minor other issues, have been fixed.
    My dealer did not know they had the firmware update until I gave them the TSB number to look up, but it took about two minutes once he had the right USB stick.
Loading...
