Which 12v battery to get.?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PutPutMobile, Feb 14, 2018.
  1. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    It’s been a year since I owned my Pri. It’s a 2010 model. I never reached to 50mpg since I got the car and I don’t think the dealer ever changed it.
    Maybe I need a new 12v battery.? I’ll check the voltage soon but shopping around what’s a good brand battery. I heard AGMs are great. Are Optima’s pretty good? I saw one at auto zone.
  2. Tnx
    Tnx Junior Member
    Claremont, CA
    Seeing threads from a few years ago saying the Optima isn't as well regarded, and that the Toyota Truestart is the one you'd want now. I'm in the same predicament as you and just missed a great Autozone coupon. They had a 15% or 20% off coupon on an item $125+, would have been great to put towards the yellow top Optima there.
    PutPutMobile likes this.
  3. PutPutMobile
    292
    518
    Buena Park, CA
    I saw the ACDelco battery on amazon. It has great reviews for the gen 3. And a good price. I might get that if no other battery can match it.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I got a new 12 v at autozone after the new year. Was seeing the original in our 2010 slowly degrade over time. But it was in service for almost 9 years:):
    Here’s that we got:
    2B7ADB3A-C3EA-47B7-8192-94402127D8AF.jpeg 4A23999D-73E3-43BC-8A63-A43E8521AF4F.jpeg 9F490A73-3E87-4394-8182-4F8A2A9028E0.jpeg
    After the in store gift card and coupon, it came to ~$160:).
    Hope this one lasts just as long(y).
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    Whether or not the 12V battery needs replacing would not affect your mpg.
    A traction battery going weak can affect mpg. If you suspect that, the recommended solution is the Prolong Reconditioning System from Hybrid Automotive. The owner, @jeff652 is fairly active here. @Raytheeagle and others have used that system with great success to extend the life of the traction battery.
    I am assuming you have already checked tire pressure & other possible issues that can affect mpg.
    #5 Prodigyplace, Feb 14, 2018
    jeff652 likes this.
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Can you add water to that Duralast? I thought I glimpsed caps. partially hidden by the label.
    Raytheeagle likes this.
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Probably can (there are caps there);).
  8. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    stick to the oem
    edthefox5 likes this.
  9. PutPutMobile
    292
    518
    Buena Park, CA
  10. PutPutMobile
    292
    518
    Buena Park, CA
    Hmmm. Thanks. I’ll go see if I need that too.
  11. Mendel Leisk
    42,364
    They're nercessity, for safety in the event of a crash, since the battery's inside the cabin. And it should be vented to the outside, to avoid possible gas build-up.
    There are several compatible options available. With various retailers you can enter your car's data and find batteries that'll work. Pep Boys for example has this, conventional cased AGM, compatible vent port, proper posts, for around $140~150:
    Bosch Premium Performance Battery Group Size 51
    Part # 51-440BAGM
    #11 Mendel Leisk, Feb 14, 2018
  12. David Beale
    5,963
    1,990
    Edmonton Alberta
    Well, if MPGs are involved engine air filter, engine air filter, and engine air filter. A dirty one WILL drop mileage and confuse the system (you're always running a little rich). From experience. Yes, the computer tries to compensate. It appears it has trouble doing so.
    Oh, and it's a "cheap fix". ;)
  13. PutPutMobile
    292
    518
    Buena Park, CA
    Already changed it.
  14. PutPutMobile
    292
    518
    Buena Park, CA
    Thanks. I’ll go check it out.
    Raytheeagle and Mendel Leisk like this.
  15. mpgz
    mpgz Junior Member
    24
    Indiana
    I'll second this. 12V battery has nothing to do with your MPGs.
    I did just have to change mine though. 6-7 years is about normal for the 12V. I have a 2011 that I bought in April. I didn't quite make it 7 years. I suspect yours may be due if it wasn't already replaced. If it dies, you won't be able to turn the car on, even if your traction battery is full charged. You can have a shop test it for you, usually for free. I noticed it getting weak when I drove at night. The lights would be pretty dim until the car turned on... more than normal. I put a trickle charger on it, and that held me over until I replaced it.
    If you do replace it, I recommend just sticking with the OEM Yuasa or the Optima. In my search for other options, many showed up, but none of the reliable brands seemed to have the proper vent connection you need for the Prius application, and some required minor mods.. which I didn't have time for. The off-brand options didn't come at a huge cost savings either. Like this one:
    . I paid $10 more for the exact replacement, Made in Japan, Yuasa OEM battery from the dealer 5 min away.
    Both the Yuasa and the Optima are plug and play. Both are stupid expensive (>$200). Dealer will stock the Yuasa. Nobody will stock the Optima. You will need to order it. Just make sure you buy from them directly or from an authorized dealer or they won't warranty it. Product Finder | OPTIMA Batteries
    All that being said... you probably don't need a 12V battery. Check the top of the battery in the trunk for a date. <5 years, you're probably A-Ok.
    #15 mpgz, Feb 15, 2018
    LasVegasaurusRex likes this.
  16. PutPutMobile
    292
    518
    Buena Park, CA
    Thank you for the info. I’ll go check out the voltage and date. Since I need to go for routine maintenance. Dammm those batteries are expensive.
  17. Mendel Leisk
    42,364
    Not all batteries have a date; the stock Yuasa does not, has only a coded date in a number.
    I thought an ailing 12 volt battery could impact mpg? (n)
    padroo and PutPutMobile like this.
  18. PutPutMobile
    292
    518
    Buena Park, CA
    Me too. I thought it could impact also. Oh well. I guess it’s normal for my mpgs.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    My OEM battery lasted 7 years. My new yellowtop lasted 3 years before it went dead overnight out of the blue. The guys at Autozone were pretty cool about and gave me a new battery for $20.
    But if I had to do it again I will buy the OEM battery.
    Xterra72, JC91006 and Raytheeagle like this.
  20. PutPutMobile
    292
    518
    Buena Park, CA
    Is the Toyota dealer the only place that has the OEM battery??
