Which 12v battery to get.?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PutPutMobile, Feb 14, 2018.
  1. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    I saw this online. do not know if it’s any good. It has great reviews for the Gen 3.
    Raytheeagle and Mendel Leisk like this.
  2. JC91006
    16,936
    8,647
    I have one in my gen2, works flawlessly
  3. PutPutMobile
    292
    518
    Buena Park, CA
    Thanks JC for your input. I might get this soon when I measure a weak voltage of my old battery.
  4. frodoz737
    frodoz737 Top Wrench
    4,797
    2,560
    33
    FWIW...saving $40-$50 on a 12VDC battery is good...all things being equal. But...with the published history HERE with "Yellow Tops" and the unknown with others, my vote and money went with the Toyota supplied option when the time came and comes again. Either-way, $40-$50 won't cover one dinner for 4 at a family restaurant with tip...so the choice and priority is yours to make. ;)
  5. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    First, I would never buy a battery and have it shipped to me, unless there was no other option.
    While rare, warranty issues do happen and I do not need nor want the hassle of having to ship back a battery.
    Personally, the Toyota offers some advantages as mentioned. Yes, you will pay more, but it has a good warranty and will fit -- exactly. I think IIRC, it now even comes with Roadside service for a couple of years or so,
    AzWxGuy and leeb18c like this.
  6. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    I agree with getting one locally unless the price is so much cheaper. With that said, I got my Optima from Pepboys when they have 25% off online order and pickup in store. It seems like they exclude Optima from 25% now but Bosch AGM is $142+tax with 25% off. Most of my other cars uses Costco batteries but Costco does not carry Prius size battery in my local stores. If you live close to AdvanceAutoParts store, they usually have big online coupons frequently so that may work if you don't need the battery urgently.
  7. cyberpriusII
    1,157
    1,850
    Hyampom
    TrueStartTM Features from Toyota
    • 84-month warranty
    • Coast-to-coast warranty service at more than 1,200 locations
    • 24-month emergency roadside assistance/towing and installation labor
    • Matrix radial grids for high-current starting demands
    • Quicker recharge capability due to the correct balance of Cold Cranking Amps and Reserve Capacity to provide power and cranking ability
    • Extended battery life due to a patented lead alloy feature that reduces corrosion
    • Improved heavy-duty lugs on the positive and negative plates to allow a greater flow of power
    farmecologist and Prodigyplace like this.
  8. PutPutMobile
    292
    518
    Buena Park, CA
    How much do they cost at the dealership? I can install it myself.
  9. bisco
    52,807
    they're all different. list price is probably low to mid 200's. call around, some dealers have 15% off coupons.
  10. PutPutMobile
    292
    518
    Buena Park, CA
    Ok I will thanks.
  11. bisco
    52,807
    i see it at camelback toyota for $183.65
    owned by warren buffet. interesting, i did not know that.
    Raytheeagle likes this.
  12. mpgz
    mpgz Junior Member
    24
    Indiana
    I paid $220 for my Yuasa at the dealer. That AC Delco battery is not one that I came across... could be an option worth trying. Some conflicting reviews, but most of the issues seem to be from Gen 2 owners.
    As far as the 12V battery affecting MPGs, I'm no expert... I guess all I really can say is that I don't think it would impact mileage, because as mine slowly died over the last 6 months, I saw no corresponding mileage loss.
    padroo likes this.
  13. Mendel Leisk
    42,305
    I'd go for the Pep Boy Bosch AGM battery if I was in the States, at least give it a try. What is it, $145 US, installed?
  14. benagi
    benagi Active Member
    525
    280
    Utah
    My 2012 Prius v stock battery died just under 6 years old. I replaced it with the Optima yellow top. They had a great sale at Pep Boys at the time. Also, Amazon had good reviews.
  15. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Thank you cyber for the feature list. I didn't know about the roadside assistance. I began my TrueStart adventure this past Monday, purchased at my dealer and installed myself. Replaced my 8 year old OEM 12V, which although not a record certainly says that the original battery can go quite a stretch.
    The purchase price was $241 less a $15 core charge. It took me about 10 minutes to install.
  16. PutPutMobile
    292
    518
    Buena Park, CA
    Hey Mendel. Have you tried the Bosch batteries in your Pri.? Do you have to get larger connectors or it would fit like the OEM battery? I’ll go see at pep boys tomorrow.
  17. Mendel Leisk
    42,305
    Never had one, just the spec's and price look good, it's readily available, and I'd assume it's exact fit, regarding dimensions, posts, vent.
    I have an optima yellow top right now, but am gathering it's got excessive CCA, and amp hours are low, for the application.
    Up here I'll probably go for a Canadian tire motomaster battery next time, a conventional cased AGM, that's likely s rebadged Exide. Again I'd expect it to be exact fit.
    #37 Mendel Leisk, Feb 24, 2018
