Which 12v replacement to buy?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Samosa, Mar 26, 2019.
  1. Samosa
    Samosa New Member
    Oregon
    2007 Prius base model:
    looks as if my 12v is dead; it was showing lower charges while in standby and running, and then yesterday i couldn’t unlock the doors (had to use key and the lock button wouldn’t do anything inside the car either) or use any of the lights+couldn’t start the car.
    So now I’m shopping around for batteries, and they range from $135 at carquest (car quest auto craft) to $205 at Toyota dealership.
    I found one at Napa that is a AGM for $186, but I don’t know the difference between all these, or if there is a difference. It looks like the main concerns are the size of the battery, dimesionally, and the inclusion of a vent. Anything else I should be taking into consideration / any cheaper batteries or reasons not to go with the cheapest one, from car quest?
    Thanks
    49,393
    go with the cheapest one that's agm, vented and correct size. safety is important
    padroo likes this.
  3. padroo
    padroo Senior Member
    2,763
    2,250
    Is there a difference in cold cranking amps and at least a three year warranty. I am not big on warranties but batteries are an exception. Some have four year warranties.
  4. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Bisco's a safety nut. My wife's 1970 VW beetle used a non-vented, non-AGM battery that is mounted under the back seat, inside the passenger area. The only thing I'd worry about that battery is it falling through the floor due to corrosion. There's a lot more to worry about that car than the 12V battery. Still in daily use by our neighbor.
  5. bisco
    49,393
    an ounce of prevention is worth a pound of cure. don't ask me, ask grandma bisco :cool:
  6. RobH
    RobH Senior Member
    2,369
    979
    70
    You an oops?
  7. bisco
    49,393
    i never heard the hole story (n)
  8. Samosa
    Samosa New Member
    Oregon
    Correct size as in?
  9. AquaJan
    AquaJan Junior Member
    47
    17
    US
    Places that sell batteries usually can tell yes/no on whether this battery fits your car. The Prius' battery compartment will only accept a certain size battery with correct terminal placement and vent port.
    I just replaced the 12v in my 2007 w/sks with a Bosch 51-440BAGM from PepBoys for $155.So far so good.
    Easy job but watch several youtube vids before you start.
    btw, The battery I replaced was an Optima Battery from 2013! Still available but very pricey
  10. bisco
    49,393
    length, width, height, terminal post diameter and position
  11. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    Personally, from my research, CARid has the Exide battery for about $153? and it's the only one I found with a full 4-year warranty. You can't get much cheaper and that's a good warranty.
  12. AquaJan
    47
    17
    US
    I'm seeing $173 plus $19 shipping for the Exide S46B24R ...did you have a coupon?
  13. oldtechaa
    336
    222
    NZ
    2013 Prius Alpha
    No, it looks like they killed the Edge and now have the Marathon Max, which is probably the same thing, but it looks like it's gotten more expensive. You still might consider whether it's worth it. With the warranty, it's still better than all the other cheap options, but compared to the Toyota battery, it's up to you whether the extra 3 years of pro-rating (on the Toyota) mean $50 more to you.
  14. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Does you car have SKS or not? They only make 2 sizes. If your car does not have SKS you might want to get the SKS battery and a new battery tray from the dealer to fit it. The tray is not that much and the non SKS battery is more and harder to find. You would get a more powerful battery also.
  15. marcas
    marcas Junior Member
    belfast
    Excel
    Here's a good deal in the UK now for the Gen 2 replacement 12v battery...
    Lion 054 Battery with 3 Year Guarantee - Product Code: 444770541
    It's just about £40 after deductions and is a higher spec than the Yuasa battery that was fitted. I fitted one in our 2007 Gen 2 Prius...the only thing is the battery posts are reversed but the earth lead reaches ok & I made an extension metal strip for the positive connector...all good so far
