Which 4 gauges do you use on your ScanGauge II?
Discussion in 'Gen 3 Prius Technical Discussion' started by rdalemercer, Jun 13, 2010.
  1. rickkop
    rickkop New Member
    93
    16
    Syracuse, New York
    Wow that's interesting. I will have to take a closer look at the instructions. Thanks for the advice. Rick
  2. rickkop
    rickkop New Member
    93
    16
    Syracuse, New York
    I read all about the x-guages and finally got the nerve to try it. Am now monitoring rpm, ice coolant temp, instant mpg and inverter coolant temp (x-guage). Have a question though. Now that I am monitoring the inverter coolant temp what should the nornal temp be?
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Mine usually runs about 20 or so degrees F. over ambient temperature. There is no thermostat (cooler the better) so it doesn't stay within a consistent range the way ICE coolant temp does.
  4. JJB
    JJB New Member
    39
    Alpharetta, GA
    Keep us posted on this. You may have given me a reason to buy a pro clip mount for my evo.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Bummer, already have the SG-II, but selling it and getting Torque + Adapter shouldn't be too hard. Downside is you'd need to run the phone plugged-in or the BT would tank the battery in a hurry.
    I currently display engine coolant temp, ICE RPM (gratuitous version), HV battery amps, and GPH. Sometimes I'd switch between regen request, braking friction, MG1/MG2 torque, MPG, etc, but AMP and RPM are almost always on.
  6. tumbleweed
    4,067
    687
    Eastern Oregon
    Always on: RPM, ICE Coolant Temperature, and HV Battery Amps
    The fourth one is what ever I'm interested in at the time, MG1 Temp, IC Coolant Temp, Ign Timing, etc.
  7. markf57
    markf57 Junior Member
    78
    17
    Longmont, Colorado
    How is GPH better than just MPG? And what is the sweet spot for GPH?
    Thanks,
    Mark
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    All I can say is Wowser!
    Is the picture you posted your setup from your own android device?
    I joined the Torque forum at
    Torque — OBD2 Performance and Diagnostics for your Vehicle
    and am starting to read about it
    so far I have more questions than answers. Would you share some of your findings with us?
    Which interface do you recommend.
    Does it matter which version of Android you use, IIRC I saw that it works on 1.6.
    Would it work with other Android devices like tablets or netbooks? I don;t have any interest in an Android phone and could use a bigger screen than a phone.
    How about you starting a new thread to highlight what Torque does so we don't hijack this ScanGauge thread.
    Thanks for posting that Torque info.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    streaming Pandora pretty much requires me to plug in a lot anyway
  10. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    This is interesting, but it presents two issues:
    1) I am using my droid as a GPS and portable internet radio player so using it as a real-time trip monitor means that I need another phone for the other two
    2) does the OBDII port charge or maintain the charge of the phone while it's being used?
    The gauges that are useful to me right now are RPM, FIA and 12V battery charge and MPH. I will soon program some xgauge options.
    On a related note, before selecting the "HYBRID" option that prevents the 5 sec timeout, my average and instantaneous MPGs looked close to the MFD values. After selecting the "HYBRID" option, it is about 67% less than the MFD. So if the MFD shows 45MPG, SG shows ~15 or so. Any ideas?
  11. markf57
    78
    17
    Longmont, Colorado
    Have you checked engine displacement size?
    Mark
  12. ystasino
    793
    50
    Tucson, Arizona
    I set it to 1.5 liters before I discovered the "HYBRID" setting. So the MPG gauges stopped working properly after I set it to "HYBRID". I wonder if I entered some wrong information or setting with my first tank.
  13. malowitz
    malowitz Junior Member
    Des Moines, Iowa
    Can you use Torque to reset the back-up beep, headlight off delay, etc?
  14. Don3755
    Don3755 New Member
    Space Coast, FL
    Does this app also allow you to disable reverse beep like the SGII?
  15. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    Looks really great. Can you think of an inexpensive way to do this if you don't already have an android device (ie what are the costs of cheaper android devices)?
  16. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    You can buy a used android phone on ebay or craigslist.
    This is has evolved a lot. They are adding all the PIDS for the Prius. It does things like MG1 and MG2 speed. MG1 and MG2 temp and many specific Prius functions.
  17. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    Will Torque and an Apple to OBDII cable be available for ie4 devices?
  18. Judgeless
    1,821
    255
    Cleveland, OH
    Torque runs on Android OS with a Bluetooth OBDII adapter. Not sure what ie4 is.
  19. Judgeless
    1,821
    255
    Cleveland, OH
    Check out this screen shot I took today using the latest version. It shows MG1, MG2, ICE RPMS and temp.
  20. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Very cool. Are those available only with paid version? Thanks.
