Which Driving Mode Do you use?
Discussion in 'Gen 4 Prius Fuel Economy' started by Robos1020, Oct 16, 2016.
  1. Prodigyplace
    12,713
    11,848
    Central Virginia
    The climate control has a separate ECO button on the 2017. The ECO mode does not change the fan speed, though. That can have quite effect on MPG.
    My son, who had a Gen 2 Prius & now has a Gen 3 (Prius v) thinks the Gen 4 ECO mode is like the older PWR mode. He usually runs ECO on his Prius v, I think.
    BTW, so far I have only used ECO mode.
  2. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I believe my 2016 has an eco button down by the HVAC controls, but I can't swear to it. I bought the car, set the temp at 70 and haven't looked at it since.
    Prodigyplace and RCO like this.
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Yes, there's an Eco button in the HVAC controls on the Gen 4. Selecting Eco on the drive mode, however, will automatically enable Eco for HVAC.
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    My Prius doesn't like ECO MODE. And I don't either.
    I think it's more than just gas pedal "feel." I think the eco mode also restricts the engine performance in some way; (and as you mentioned it also restricts the air conditioning.)
    Now days, I just always leave my car in the Normal mode. It's a good compromise, and everything seems to run better. And the displayed mpg can be as much as 4 miles per gallon higher, when I take it out of the eco mode. However, after going through a full tank, all three modes are pretty much the same with regards to mpg.
    I'm not even concerned with mpg anymore. Only time I glance at it is when I fill up the tank. (And anything over 40 is great! :LOL:)
    Felt and RCO like this.
  5. Mendel Leisk
    42,347
    There you go. I look on it like spark plug temperatures. The car builder comes up with a sweet-spot plug, and might also allow one that's hotter and colder. But for the vast majority of conditions, just sticking with the normal plug is the way to go.
    Felt, RCO and Coast Cruiser like this.
  6. Coast Cruiser
    2,267
    2,571
    I also put my tire pressure back down to normal, factory specs. Haven't noticed any decrease in mpg for the last 300-400 miles. And the car suspension feels much more smooth and comfortable.
    It took eight months of experimentation, with various driving modes and different tire pressures. But as you say, for the vast majority of conditions, normal is probably the best way to go. I'm happy. :D
  7. MrMischief
    426
    443
    Denver CO
    So funny because i went from daily driving an SUV that could hit 18 mpg on long easy drives, but typically I was around 14 or less. now I get mad whenever a tank is under 60 mpg.
  8. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    Prius drivers are the only group that uses the words "only" and "60 MPG" in the same sentence.
    Bab F, Felt, RCO and 5 others like this.
  9. Coast Cruiser
    2,267
    2,571
    :ROFLMAO: :ROFLMAO: :ROFLMAO: Thanks thunderstruck, that really made me laugh! :)
    RCO, MichelleStone and Prodigyplace like this.
  10. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, DRCC uses harsh regen/engine braking going downhill (or when slowing down for traffic) just like being in "B". I thought something was wrong when I first felt/heard the windup in rpm in my 2016 Prius having never experienced it in my 2004 Prius.
    JeffD
    #110 jdenenberg, Nov 10, 2016
  11. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    Historically every single car has multiple power modes. And the name of these modes is downshifting.
    Even most cars with auto transmission, like my well beloved (and now traded in) Camry Solara, have a manual mode. So is I push a stick to the left, a gear box downshifts from 5 to 4. This used to be my favorite version of power mode (or its equivalent, if you will), if I need to take over on a highway.
    I think similar idea should be applied to CVT with the difference that an actual gear ratio is govern by how soft/hard you are going to be on the throttle.
    Now a few words why I drive my 3 days old Prius in Eco mode: I just would like to insure be easy on the drivetrain during first 1-2K Km of braking-in.
    #111 alexgrigori, Nov 11, 2016
    Coast Cruiser and RCO like this.
  12. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Amazingly on the EU version, setting ECO mode does not set the HVAC to ECO (from FAST or Normal settings) as far as I remember.
  13. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The EU Manual (online) states:
    Eco drive mode
    Suitable for driving that improves fuel economy by generating
    torque in response to accelerator pedal operations more smoothly
    than in normal mode.
    When Eco drive mode is selected, the “ECO MODE” indicator will illuminate
    on the main display.
    While the air conditioning is being used, the system automatically
    switches to air conditioning eco mode (→P. 471), allowing for driving
    that leads to even better fuel economy.
  14. greenmonster01
    106
    79
    Southeastern MA
    Eco mode almost exclusively. I've tried normal mode one day on my commute in to work, and didn't like the resulting mpg. I have used power mode a few times on the hilly portion of my commute, but just mash the pedal down when I need power in eco mode.
    I like the fact that eco mode also puts the HVAC into a more economical mode... Now that it's colder in the mornings, I've started to wear my wool socks instead of turning up the heat (and/or turning off eco hvac).
    RCO likes this.
  15. Prodigyplace
    12,713
    11,848
    Central Virginia
    I understand the earlier Prius had electric heating. In Auto mode, mine appears to stay off until. I assume, the engine warms up. Switching the climate control from Eco to Normal does not appear to help.
    Did they eliminate the electric heat for Gen 4? I think all trims use the same climate control system.
    RCO likes this.
  16. greenmonster01
    106
    79
    Southeastern MA
    It still has a heater... I'm probably just spoiled from my acura cls being warm all the time, and I'm just making the adjustment to a more eco-friendly heating enviroment.
    The way it's written in the toyota press release makes it appear to be an eco trim feature only, but I'm guessing it was just a faux pas by the writer...
    Return of the Disrupter: All-New 2016 Toyota Prius Rewrites the Hybrid Rule Book It Created | Toyota
    "In cold weather, a positive temperature coefficient ceramic heater warms the cabin quickly without relying on the engine coolant to come up to operating temperature."
    RCO and Prodigyplace like this.
  17. Prodigyplace
    12,713
    11,848
    Central Virginia
    I know the Eco supposedly has heat-insulating windshield glass. Not sure about the heater.
  18. thunderstruck
    154
    151
    Port Charlotte, FL
    2022 Prius
    My engine has been kicking on almost immediately the past few mornings, but turning climate off shuts it back off again. Water temp has been pretty low when I checked with SG, around 112-115. It goes up some after engine has run for a while, and thats when I turn heat on. I don't mind a little discomfort if it helps with mileage.
  19. Mr.MPG
    Mr.MPG Member
    30
    50
    Southern California
    Four Touring
    Normal Mode: Ave 80MPG.
    krmcg and RCO like this.
  20. alexgrigori
    163
    109
    Technology
    I found that the hood of my car does not have thermal insulation. Is it normal especially taking into account that this is Canadian version?
