Which gas stations/brands do you trust?
Discussion in 'Gen 3 Prius Fuel Economy' started by RaZa, Dec 8, 2011.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    NOVA is Northern Virginia, sorta like North Jersey, but don't get me started on North vs. South
    We actually have a few widely spaced WaWa stores, but 7/11 rules
  2. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Most ANNOYING in Calif is ARCO. They charge if you use your debit, have PIA central kiosks and they have the highest ethanol content of the majors.
  3. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    anything but BP (noticed a 4-5 mpg lower difference.) Citgo...we don't support the anti-American Hugo Chavez.
  4. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I have been using Hess for 6+ years, no problems. They are usually the cheapest gas in town.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Murphy USA
    You can select to only see Murphy stations at a Walmart.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have used the Wilco-Hess gas for years. Hess has a tank farm at the state ports with ocean tankers arriving weekly. So, I know their gas is probably the freshest in the area. They are also the cheapest.
    As one other said, I see all kinds of gas company tanker trucks pulling out of the Hess tank farm area. I have seen where others have said that the different companies add different additives to the tank trucks. So, who knows whether the top shelf Exxon-Mobil, BP, Shell, etc. actually do add the additives or not ?
  7. Anomoly
    Anomoly Junior Member
    35
    Cali
    My wife gets upset because her family owns a company that builds gas stations, my father-in-law worked for mobil for over 20 years before that, he knows a lot about gas, gas stations, and gas station owners... he says, 'it's all the same, it comes from the same place, and it all burns the same'
    Even with that advice, i'm biased as i used to use only cheap gas with my old car and i noticed a difference even in MPG when using cheap vs expensive (both 87 octane) maybe it's all in my head but that being said:
    I mainly use 76/phillips, mobil or shell... they can be maybe 5-10 cents more expensive per gallon but when your looking at filling up say 10 gallons... your paying 50 cents to a dollar more... peace of mind is worth atleast that in my eyes.
  8. Jim E.
    Jim E. Junior Member
    48
    Eagle Lake, MN
    Burnsville Toyota gave me two lifetime .04/cpg discount cards for Kwik Trip, and Toyota says Kwik Trip is on their approved list of "premium retailers" for having trustworthy gas. Whatever that means. Probably that they haven't been caught on video yet pouring water into their underground tanks after midnight.
    Price per gallon at Kwik Trip is usually .04 higher than surrounding stations, so I basically "break even" using my card. So my real reason for using them is bananas are always .38/lb, and the folks there seem nicer.
  9. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Wherever is cheapest.
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
    NJ and Oregon.
  11. El Dobro
    El Dobro A Member
    7,106
    3,282
    That was Texaco. They had Fire Chief and Sky Chief.
  12. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    If I'm looking for the best mileage per tankful......then it's Mobil. If I'm a few $$ short and need gas, then it's Hess.
  13. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Shell or Chevron.
    Any link to where you obtained the info regarding the Ethanol content?
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Usually Costco if I am near there. Otherwise a station that looks like it sells a lot of gas and is fairly clean and well maintained. If I'm on a trip and running low it's "any port in a storm, mate".
  15. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Shell or Gulf.
    I never use the cut-rate stations. Years ago, I had several cases of bad gas and in one case, a mix of diesel and gas.
  16. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    After seeing the thread I was going to say the same thing - the gas in all stations comes from the same wholesalers. From what I understand just about all of the stations will get tankers from the same place and some of the name brands will put their own additives - such as the Shell nitrogen enriched gas that they advertise.
    Same thing goes for milk - the local store brand and dairy will be exactly the same even though the store brand will be significantly less - with milk it is pretty easy to confirm as there is an alphanumeric code printed on the bottle just below the opening that show the facility where it was bottled and the date it was done.
  17. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Costco - consistently $0.10 to $0.20 less than all others. All gasoline comes from a nearby common refinery.
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Didn't see this in owner's manual, but the Honda manual recommended ....
    Top Tier gas. Check their website for a list of vendors.
    I use Shell in Prius. Couple of Shell stations close by.
  19. oldasdust
    oldasdust Member
    356
    47
    illinois
    In my area same price these days cut rate or top tier so i use Shell or Bp. They give me the best mileage. The cut rate stuff mileage falls off about 3 tested for years in five different vehicles.
  20. GoMetricToday
    GoMetricToday 42 is the answer to the ultimate question.
    64
    Erwin, TN
    I stay with Murphy USA because they have their own refineries, their own stations, they are usually about .05 to .10 a gallon less than the competition in the area. In most places where there is a Wal Mart, there will be a Murphy USA station. But Murphy USA also has it's own stand alone stations off the Interstate system. In essence they sell their own gas and diesel at their own stations. They may sell their gas and diesel to independent stations. But in their own stations it is their own product.
