Which headlight assembly for 05 prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SteamPowered, Apr 28, 2014.
  1. SteamPowered
    SteamPowered Junior Member
    39
    Arizona
    So my headlights are discolored and hazy and I'm thinking about replacing the assembly altogether.
    I'm shopping around but I only find 06-09 headlights, i.e. those with the faux LED strip. Are these headlamp assemblies compatible with my 05 prius or should I look harder?
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Why not purchase one of those headlight lens restoration kits? A lot less $$ than buying the entire assemblies.
    SCH-I535
  3. SteamPowered
    39
    Arizona
    I did and used one. Even made sure to get one with a sealent. It lasted a year, which actually seems on the high end. Now they are dirtier than ever.
    Instead of spending $20 and an hour of work every 12 months, I figure replacing is the better bet.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    any pics of your "needs to be replaced" headlights? Jess wonderin if the next set will get equally dirty every year.
  5. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    The kits are unnecessary. Just wet sand with 1000 grit, then 1500 then buff with a buffing compound. Once you get them clear, wax them and every time you wax the car wax your lights. It acts like sunscreen for the lights. Even if you buy new ones the sun and acid rain will do the same thing. Just keep them clean and waxed and they will stay looking nice.
    JC91006 likes this.
  6. SteamPowered
    39
    Arizona
    They are cloudier than any prius i've seen, and cloudier than any late generation car. I doubt everyone else is treating their car every year so I will consider replacement. I appreciate the suggestions for using a kit or sanding but this is just too much work for me since I don't have the tools.
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    My niece just had her headlights restored for $30 at a Sam's Club tire shop. If you can get a similar price, you could restore your headlights every year for 10 years for the same price you'd pay for new headlights.
    Plus it's doubtful you'll be hanging on to your Prius for 10 more years anyway.
    SCH-I535
    kenoarto likes this.
  8. yzfrider2001
    yzfrider2001 Junior Member
    23
    My wife's prius's lights did the same. Get a restoration kit and then wax them (I use TW Ice). They have been clear going on three years now.
  9. SteamPowered
    39
    Arizona
    I don't have a sam's club. Anyone have any recommendations or is this a general service many places will do?
  10. JC91006
    16,909
    8,631
    You can get a kit here and do it yourself
    Edit: wow, no more links show up!!
    Anyways, go to amazon.com and search for headlight restoration
  11. yzfrider2001
    23
    Why on earth would you need to go to Sams? Do you have a drill or can use plain elbow grease? It's incredibly easy and paying for the service, well, doesn't make any sense.
  12. quietmouse
    quietmouse New Member
    Colorado
    If you're set on purchasing a new set i'd check with your local parts store or dealership, they may be able to point you in the right direction. My dealership recommended Genuine Toyota Parts on the web if I was looking for something at cost or wholesale. I didn't get a chance to follow up, found a set on craigslist, may be worth a look though...
