which inverter part number do i need?
Discussion in 'Gen 3 Prius Technical Discussion' started by Metaleckz, Aug 16, 2021.
  1. Metaleckz
    Metaleckz Junior Member
    23
    San Francisco
    I have a 2010 Prius with a bad inverter. I replaced it sometime last year and it happened again. I was told by a mechanic to buy a 'newer' or updated inverter because they are more robust and when i looked it up here on the forum, i saw about 3 part numbers and i don't know which one to get
    G9200-47190
    G9200-49025
    G9200-47140
    there could be more part numbers but which one is the updated part number that will work on my 10' prius.
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,062
    6,933
    Texas Hill Country
    The part you need is best found from a dealer using your vin. If a superceded part number is available, they can give it to you. Some dealers sell online as well and will recommend the part based on your vin.
    You would be better off with a new inverter with updated transistors but you can't just go to the junkard/ebay and buy one from a later model as it may not work at all or it may have the weaker parts yours had. In the end, its get a new from inverter or repair a dealer or buy used and hope for the best.
    Finally some people buy an ebay inverter and successfully install it only to later find out a trip to the dealer could have saved them big. Don't be that guy.
  3. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    On the McGeorge Toyota website, it's only listing the last one (G9200-47140) for your model and it's $2,266.47 (retails for $2,928.28) so a pretty nice discount of 20%.
    Their website is https://toyotaparts.mcgeorgetoyota.com
    Metaleckz likes this.
  4. ChapmanF
    18,997
    By the way, what was the 'it' that happened last time, and what's the 'it' that happened this time?
  5. Metaleckz
    23
    San Francisco
    first time, my prius inverter died and i couldnt move it at all. it would only go to neutral and the engine wouldnt start. i bought a used inverter and that worked for a while and now, my inverter died again but this time, i can still drive the car but on "limp mode" (only up to 30mph and only the ICE is functioning but not the hybrid system)
    Fostel likes this.
  6. ChapmanF
    18,997
    Did you retrieve diagnostic codes either time to find out what the problem was?
    A car without a functioning inverter cannot drive. There is no mechanical transfer of power from the engine without the inverter to manage MG1.
  7. rjparker
    11,062
    6,933
    Texas Hill Country
    Don't forget Toyota may replace it free.
  8. Metaleckz
    23
    San Francisco
    I actually went to the dealer and they voided my warranty because i have replaced it last year and they found out that the inverter installed now is from a junkyard. I emailed toyota to see if they can do this one for me, lol
  9. Metaleckz
    23
    San Francisco
    Usual P0A7A and p0a94
  10. rjparker
    11,062
    6,933
    Texas Hill Country
    I guess you are that guy. Don't feel like the Lone Ranger, many don't sign up with Toyota to get recalls and customer support program notices and learn too late Toyota was ready to help. Priuschat does not help sometimes when they advise people to diy and avoid the dealers. Its 15 years on the inverters.
  11. ChapmanF
    18,997
    Did you have those exact two codes both times?
    The codes are sometimes worth knowing if you're looking at the price of the whole inverter assembly, because in Gen 3, the IPM, converter, and MG ECU are all available as replaceable components.
    Yes, replacing either the IPM or the converter requires a fussy procedure involving heatsink compound (and if you're not fussy enough, you'll get to do it again with new parts). But in cases where only one has failed, it can shave a bunch off the parts cost.
    In this case, if there's both a P0A7A implicating the IPM and a P0A94 implicating the converter, it might just be less trouble to replace the whole assembly.
    The repair manuals on TIS get ongoing updates, and for anybody referring to old downloaded PDFs that circulate on the web, the sections about inverter and converter component-level diagnosis and replacement are way more complete now than they were in the downloads that circulate.
  12. STEPHEN CARMICHAEL
    STEPHEN CARMICHAEL New Member
    NEWTOWNABBEY
    2012 Prius+ MPV
    Excel
    Sorry for jumping on this thread but I actually got the recall done about 6 months ago and my inverter failed a few days ago, been looking at replacement part but alot of different part codes for the same part, going to ring Toyota tomorrow, doubt il get anywhere but if I can atleast find out which inverter part codes are suitable for a 2014 Prius plus il he happy
  13. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    They did the recall and it failed? Certainly take it back. It should be covered by there warranty.
  14. STEPHEN CARMICHAEL
    NEWTOWNABBEY
    2012 Prius+ MPV
    Excel
  15. STEPHEN CARMICHAEL
    NEWTOWNABBEY
    2012 Prius+ MPV
    Excel
    How long is the warranty in the UK? My car is a 2014 but I've 196000 miles on it
  16. ASRDogman
    8,055
    4,083
    I have no idea of the warranty in the uk.
    I was talking about when the did the recall, and when the inverter failed. How long was it, mile wise?
    The recall was suppossed to keep the inverter from failing.
    You should still return to the place that did it and have them check it out, purhaps they will replace it at no charge to you.
  17. tony_2018
    tony_2018 Member
    227
    68
    super weird that the inverter fails again.
  18. aucomp1
    aucomp1 New Member
    Rye, Vic
    2010 Prius in Australia. The inverter recently died and Toyota wanted $5k to replace.
    After extensive research decided to source a second hand newer model online.
    Managed to find one out of an Auris (UK car)
    Original: G9200 41740
    Replaced by: G900 41790
    Took around 8 hours to remove and replace, all working fine now.
    Of course only time will tell.
    Fostel and ASRDogman like this.
