Which is worse: AC or windows down?
Discussion in 'Gen 2 Prius Fuel Economy' started by Mondrin, Jun 29, 2008.
  1. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Well, I guess you could say it accounts for it, but only to the extent that the simulator has two settings for climate control -- one for whether it's on and the other for the temperature setting. I'm guessing it assumes a "maintenance" mode of sorts for cabin temperature that has already reached the set point, and that it does not consider the initial burst required to cool a sun-baked cabin.
    I've thought about charting the current flow with AC in my own car, similar to how I've reported other operating parameters here. But knowing the inevitable MPG hit, I just can't bring myself to turn it on.;) Maybe I'll do it the next time m'lady's riding with me. She doesn't tolerate wind in her hair or hot air in her face. :p
  2. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    So do you stand behind her when talking? :D
    Sorry, Jim, couldn't resist!
    Have a great 4th of July
  3. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Safest thing is just to keep my mouth shut completely! That way I don't get hit and she doesn't get burned. :tape2::bolt:
  4. Jack66
    766
    Stafford, Virginia
    I've been putting the windows down for the first five minutes to cool the Mystery Machine down then turn the AC on to 75. I've been getting 53 MPG - normally I'm around 48.
  5. go4less
    go4less New Member
    nova scotia
    Windows vs A/C has been talked about for years---I have no plans to drive in hot days without air. But I will make sure as not to over cool. When I get my 2008 Prius in Aug I will follow a lot of the tips and try to get the best mpg that I can but within reason.
  6. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Rather than opening windows, run your blower at high speed--forcing outside air through the vent system. Lower drag than open windows. You can also run your AC for short times with internal circulation, for quick cooldown. Then switch to outside air through the vents. Alternate as needed. The electronic controls are simple to manipulate.
  7. doubleg2005
    doubleg2005 Member
    236
    it's been consistently 95-100 here for this month (we had one cool day at 92, which was nice) with 70-90% humidity and i drive 45 mph with all four windows down and get about 60-65 mpg. with auto ACC at 78 that drops to about 50-55, which is, interestingly, close to what I get on the hwy at 62 mph with ACC on.
    the other day i did try rolling two windows up and also all four at half-way but there just wasn't enough air flow for me and the FE seemed to stay pretty steady compared to all four down... FWIW
  8. ctbering
    ctbering Rambling Man
    1,650
    124
    Chicago Illinois
    I must be a completely self-absorbed human being oblivious to the Prius challenges to get MPG's during various weather conditions. In the summer, I open the windows when its nice outside or I set my air conditioning to 77 when its hot with the windows rolled up. If my dog is in the back seat she prefers her big head resting on the door with the back window completely open (drooling on the outside of the door). If we are on the highway all windows are up.
    MY MPG's are very good and if I have to sweat profusely to save on MPG's I think I would have to revaluate whether I should continue to subsidize my Caribou decaf vanilla coffee cooler habit.
  9. jammin012
    jammin012 The man behind The Man
    510
    Cali
    Windows down is worse. You smell more of the crap outside and the air rushing through your cabin will take it's tollon your interior. AC on is the way to go.
  10. metamorphosis
    metamorphosis Junior Member
    22
    New Zealand
    Just to raise this thread from the dead - do people here realise you can (on a gen2 at least, unsure about later) turn A/C off, keep the fans on, move the temp down to max-cold, and it won't use any energy, just funnel the unchanged air in from the outside? So you can get max airflow from outside through your fan system, rather than opening windows.
    This has always been obvious to me, but reading a couple of these threads on priuschat, seems like people here don't realise this?
  11. ChapmanF
    19,025
    The fan uses energy. At a small rate compared to Max A/C, but not negligible.
    The A/C is variable power, too. At max, it can use over two kilowatts, but at more moderate settings can use just a couple hundred watts—or cycle, a couple hundred watts, then off, couple hundred watts, then off.
    At the lower end, it may be kind of in the same ballpark as the fan. I've never measured what the fan draws at various speeds, but in my gen 3 it's on a 50-amp fuse, so probably a few hundred watts on high.
  12. BiomedO1
    BiomedO1 Senior Member
    4,600
    2,414
    Left Coast
    FWIW; you should use your AC - since the traction battery cooling air intake is inside your cabin. This makes it easier on the traction battery ECU to cool the traction battery and avoid premature failure. If your sweating, so is your traction batteries.
    Just my two cents......
  13. SilentKiller
    SilentKiller New Member
    St Cloud, Fl
    Just to add to the chaos .. driving my Gen2 mostly on a highway run at 65mph, I have seen no drop to my avg mpg's .. with or without the A/C running. Currently getting 49.5mpg as the average. When I run without A/C its because outside air temp is under 70 and I can use the fan and fresh air setting. I also subscribe to windows down below 45 mph.
  14. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Not a Gen2 owner, but I like driving cars with the windows down. Always tricky, for me at least, to not get pulsing over, say, 45mph. On my Gen5 I open the driver's window and the right rear passenger window.
  15. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    While I enjoy driving with the windows down at say 35 mph or under, I don't get the attraction of high-speed driving with the windows down. In any case, if it is below 18ºC or above 25-26ºC, the windows are always up, and the A/C is on auto with an appropriate (for the season) temp setting. If it gets too cold, I click it up 1, maybe 2, clicks on the steering wheel buttons; the reverse if it gets too hot.
    Like @SilentKiller, I do not notice any appreciable increase in fuel consumption when using A/C. I fear the effects of using A/C or not are greatly exaggerated with these newer Gen A/C systems.
    The only consideration I give the A/C is, if starting from cold, switching it off until I've been driving for 15-20 min. In my locale, being a moderate climate, this is easily done, but I do understand that elsewhere, due to OATs, it is not always possible; you just have to take the small hit.
