Which mini VCI to buy?
Discussion in 'Generation 1 Prius Discussion' started by kutcht1, Mar 6, 2015.
  1. Patrick Wong
    18,210
    6,517
    So have you gotten Mini VCI to communicate with your Prius or do you still have a problem?
    If you still have a problem, is there another Toyota around that you can try to connect to, to see if the problem is with your Mini VCI setup or with the Prius itself?
  2. bwilson4web
    16,535
    I made these screen shots this evening:
    Check the firmware version and make sure it sources from XHorse:
  3. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Just FYI,
    I found an eBay seller OBDFAMILY (supposedly the original knock off-er), that sells a MiniVCI that works with Windows 8.1 (TIS version 10.X, most current). For $39 Free Shipping.
    Mini VCI OBD2 Diagnostic Tool Scanner for Toyota Prius C V PHV RAV4 EV Rush T100 | eBay
    In desperation, I also ordered the FOTGA Brand $22.99 (strangely included all versions of the TIS 7-10.X) plus $6 shipping version for Windows XP for my left over DELL laptop with XP.
    Just go to Amazon and search FOTGA OBD2
    I did this just in case I had issues with either one. Well both installed properly on both lap tops and worked on my MIL's 02 Prius.
    However, despite both stating their products will work on all Toyota/Lexus/Scion post 1996.
    They DO NOT work on a 1996 Lexus.
    I returned the FOTGA and they refunded my money immediately, great service.
    The other company OBDFAMILY stated their K-Line supported OBD2 connector will work for $20 more. Returned and sent them the difference. Well, we shall see.
    2015 Original Mini VCI Diagnostic Cable for Toyota Lexus Tis Techstream FW 2 0 4 | eBay
    I did notice OBDFAMILY's OBD2 seems to be built a bit more sturdy, labels/stickers were not pealing and connection seems less shaky vs the FOTGA brand, at times the FOTGA connector was not seen by TIS program on either XP or W8.1, no biggy, I just reconnected the USB and it eventually saw it. Hey, what do you want for 28 Bucks :cool:
    BTW, has anyone noticed the TIS chooses 2003 for a 2002 Prius?
    #23 DRACO, Dec 26, 2015
    bwilson4web likes this.
