Which oil do I switch to if I am burning 1 quart/5k miles (2010) Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by woody23, Jun 4, 2019.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Are YOU an alien ??
    Grit likes this.
  2. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    I might be. But I didn't take it.
    Grit and CR94 like this.
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    That’s a ridiculous & childish answer. If anything the engine oil fairy came by and tapped its magic wand three times on the crankcase and said taa-daa
  4. Raphael Muscarelle
    661
    222
    No really the bike had sight glass so just look at level as your getting on it. It would be full untill 3500 miles then on the next ride it will go down a quart. Just wild really. No smoke but quart gone in less then 100 miles. And as I said i don't of any oil that goes through combustion without causing smoke in exhaust .
  5. sam spade 2
    7,035
    2,803
    2017 Prius c
    Sure it will.
    Despite what you think you saw, you did NOT suddenly lose a quart of oil in 100 miles and then magically have it be OK again.
    When the valve seals or rings start losing their seal, a small amount of oil will go out the tail pipe without any noticeable smoke.
    A mal-functioning PCV system can pump oil out too......through a drain hose but only while the engine is running.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    A quart in 3500 miles is roughly 1oz per 109 miles. It would not even be enough to get a puff of smoke on overnight startup. I would not change a thing except maybe oil change interval to match consumption interval. Same brand of oil and filter that you currently use.
  7. Raphael Muscarelle
    661
    222
  8. Raphael Muscarelle
    661
    222
  9. Raphael Muscarelle
    661
    222
    Unless something metaphysical happened. Well something chemical happened
  10. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The type of oil loss you describe is physically impossible on a functioning engine. You can not be at full for 3500 miles and magically lose a quart in the next 100. It cannot be done.
    Raytheeagle and Grit like this.
  11. Raphael Muscarelle
    661
    222
    Yeah that's what I was confounded with too. But yet it did.
  12. Raphael Muscarelle
    661
    222
    And if went through combustion chamber ... Well smoke smoke and more freeking smoke
    Grit likes this.
  13. sam spade 2
    7,035
    2,803
    2017 Prius c
    Sorry Raphael, that didn't happen.......not more than once, that is.
    Either you are overlooking some important factor......or you are delusional.
    Grit likes this.
  14. Raphael Muscarelle
    661
    222
    Grit likes this.
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Just waiting for the alien oil extraction process, NASA can really take some notes here.
  16. Raphael Muscarelle
    661
    222
    Never did catch them.
  17. Raphael Muscarelle
    661
    222
    Or where the oil was going
  18. nepbug
    nepbug Junior Member
    23
    31
    Denver, CO
    I agree, this stuff is good. You can buy it online from Ryder Fleet Products (no link as I'm too fresh to post links yet). Do a search, spendy, but good.
  19. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Although I agree that 1 quart per 100 miles with no visible smoke is very unlikely in a normal-functioning engine, I hesitate to say to say “impossible” as I have owned old vehicles that exhibited very odd and inconsistent behavior. If an external seal in the pressurized part of the oil supply system is leaking intermittently due to the presence or absence of grit blocking the leak point, you could get inconsistent leakage while driving. Still, if the oil is not being consumed during the combustion process, I would expect drips, dirty external sludge under the engine, or driveway stains from that leaking quart of oil. Tis a puzzlement.
  20. sam spade 2
    7,035
    2,803
    2017 Prius c
    The implication WAS that simply changing the oil stopped the excess usage again.......until it exceeded the "magic" number of miles with the new load of oil.
    Troll bait.
    Ed Beaty likes this.
