Which Oil Do You Use? Dino or Synthetic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dorunron, Jan 3, 2013.
  1. Regular Dino Oil
    10.9%
  2. Synthetic
    84.8%
  3. Synthetic Blend
    4.3%
  1. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I would like to see what the user's today are running in their vehicles.
    Format to reply
    Oil Type: Dino or Synthetic
    Oil Brand: Your Brand Name
    Oil Weight: Example 5W30
    Typical Oil Change Interval: 5000 Miles, 10000 Kilometers, etc.
  2. dorunron
    3,318
    1,105
    Houston, TX
    Oil Type: Synthetic
    Oil Brand: Mobil 1
    Oil Weight: 5W30
    Typical Oil Change Interval: 5000 Miles.
    Ron
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    560
    Tucson, AZ
    2021 Prius
    Oil Type: Synthetic
    Oil Brand: Castrol Edge
    Oil Weight: 5W30
    Typical Oil Change Interval: 7500 miles, change oil and filter.
    Mike
  4. bobodaclown
    bobodaclown Member
    216
    72
    PriusGuy32 likes this.
  5. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Oil Type: Synthetic
    Oil Brand: Right now, Mobil Super Synthetic (it was on sale and I stocked up!)
    Oil Weight: Right now 5w/30 but I have Mobil 1 Advanced Fuel Economy 0w/20 going in next!!
    Typical Oil Change Interval: 7,500 miles
  6. PriusGuy32
    1,417
    514
    Well that 4.0l SOHC engine is BULLETPROOF, you could've used baby oil in the thing and it would still last forever :D
    And Ive used Supertech full synthetic before, its very similar to Quaker State synthetic in comparative analysis. For the money, its a good and too often overlooked synthetic oil.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Oil Type: Sometimes full synthetic, sometimes synth blend.
    Oil Brand: Valvoline Durablend 5W30. Caltex C3 full synthetic 5W30. Castrol Edge A3/B4 FST 5W30
    Oil Weight: All 5W30
    Typical Oil Change Interval: 15000 km
  8. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Oil Type: Synthetic
    Oil Brand: Mobile 1
    Oil Weight: 0W20
    Typical Oil Change Interval: This was the first change (for me) in my recently purchased 05. Planning for 10,000 miles with a filter change halfway. We'll see. My techy son tells me the Purolator PureONE filter beats others hands down catching smaller particles.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Oil Type: Synthetic
    Oil Brand: Whatever is on sale​
    Oil Weight: Example 0W20
    Typical Oil Change Interval: 5000 Miles​
  10. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Oil type synthetic
    Oil brand Toyota or Mobil 1
    Oil weight 0W20
    Oil change interval 10,000 miles.
  11. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Oil type Syn.
    Brand- What-ever is on sale.
    Oil weight- 0-20 and change once a year. Under 10,000 miles. H
  12. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    Pennzoil Platinum with 1o,ooo mile intervals and the oil still looks clean.
  13. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I'm not real keen on midway filter changes. It's just that by the time I get my tools out, lift the car, get something to catch the small amount of oil and clean up - I may as well have done a complete oil change anyway. Personally, if I wasn't confident in filters lasting more than 5k, then I just choose a cheaper oil and do 5k oil/filter changes.
    Actually I just cut open a couple of filters (from my Prius) that had each run 10k miles. The physical integrity looked perfect on both (valves, end caps, media pleating etc). After looking at the filter construction I'd have very little concern about anything other than media loading limiting the life of the filter.
    BTW, these weren't OEM filters (dealer was charging me $23 for the OEM filters grr, so these Ryco ones work out a lot cheaper). Unfortunately I didn't take a photo before I mangled it by prying off the metal end caps, but it was in nice shape. :ROFLMAO:
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Oil type: Synthetic
    Oil brand: Toyota so far but willing to use any good brand
    Oil weight: 0W20
    Oil change interval: 10,000 miles I live in a mild climate so ignore the one year limit, run it about 16 months
    Absolutely no concern about the filter lasting 10k miles.
  15. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Oil Type: Synthetic
    Oil Brand: Mobil-1
    Oil Weight: 0w-30 Advanced Fuel economy
    Typical Oil Change Interval: 6000 give or take
    I just put in my winter refill.
    Last spring refill was Mobil-1 5W-30 Extended Performance - I went about 10000 mile on it
    Keep in mind Toyota recommends sticking to 5000 mile drain interval (Gen2) and I assume they have a good reason for recommending that.
  16. Britprius
    5,194
    1,924
    We do not know Toyota's reasoning on oil change intervals since there does not appear to be much logic about them. Gen2 Prius has always had a 10,000 mile oil change interval in UK/EU while in the US it has been 5000 miles. The gen3 version in the UK/EU has always been 10,000 miles while in the US it started at 5,000 and has since been revised to 10,000 miles.
    John (Britprius)
  17. HaroldW
    716
    95
    That is why I like my Honda 2006 Hybrid. It has a built in Maintenance Minder. It tells you when to do almost everything. Oil change every 12-15 thousand kil. "A" service includes oil filter, "B" service no oil filter. In other wards the filters is changed every other oil change. Air and climate filters, spark plugs , trans [CVT] oil change are all on this minder. I am not sure why more car company's are not using this type of system. Great for folks that don't understand how or when to maintain their auto's .:) H
  18. Britprius
    5,194
    1,924
    On the UK version of the Prius item can be put into a service menu such as breaks, tyres, filters, 12v battery, oil, and much more. I find it strange on the US gen3 the oil change is now 10,000 miles, but Toyota are not updating the software so you still get a warning at 5,000 miles, crazy.
  19. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Amsoil SSO 0-30W. Pure synthetic, I change every 25k, rated to 35k. Lab analysis good, recommend try longer!
    Alan.. Sent with Tapatalk 2
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Not from the dealers viewpoint. That gets a large share of owners into the dealers service department every 5k miles and presents money making opportunities for their service departments.
