Which Oil Do You Use? Dino or Synthetic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dorunron, Jan 3, 2013.
  1. Regular Dino Oil
    10.9%
  2. Synthetic
    84.8%
  3. Synthetic Blend
    4.3%
  1. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I believe your standard engine oils are of higher spec than ours in the US.
  2. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    ...hmm I am speechless I assume Brit you are saying UK Gen2 drain interval is 1.6 x 10K = 16000 kilometers
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I my opinion it can handle 10000 miles very well if you're using a good quality oil and not doing too many short trips (especially doing a large percentage of highway miles). Here's a near perfect (very low wear metals) used oil analysis from 2008 Prius running a 12000 mile interval!
    Formula Shell Synthetic 5w-30. 12k in Toyota Prius - Bob Is The Oil Guy
    Dino33ca likes this.
  4. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Yes, has been from day one with the gen2 this side of the pond.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It may also have something to do with oil costing more in your part of the world and people there being more reluctant to flush money down the toilet than most USians are. I can easily find Mobil 1 synthetic for $25 for 5 US quarts, sometimes less if I look for bargains.
  6. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Yes 6000 miles with normal oil not synthetic? I don't think they specify the milage when using sythetic with the G-2 H
  7. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Oil Type: Dino
    Oil Brand: Pennzoil High Mileage
    Oil Weight: 5W30
    Typical Oil Change Interval: 5,000 miles - Adding a quart every 2,000 - 2,500 miles because of the burn, lol.
    Chris
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    I switched back to dino three changes ago. Using Valvoline Max Life now and changing every 5000. That's about every two months at my current rate of travel. In that time, the engine uses a little over a quart, in the winter about a quart and a half. Pretty good for a car with over 134K on the ticker. I quit using Fram filters too, but not because of their reliability. The internet can cheaply supply me with genuine Toyota filters delivered to my house.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    That's still 5W30 right?
    Apparently Maxlife is actually part synthetic. Should work just fine for 5000 mile intervals. :)
    BTW. Have you tried their "Nextgen" maxlife, it's every bit as good as the regular stuff.
  10. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Oil Type: Synthetic
    Oil Brand: Mobil 1
    Oil Weight: 5W30
    Typical Oil Change Interval: 5000 miles, change oil and filter. No loss of oil or low dipstick reading between oil changes. 2005 Prius now has in excess of 165,000.
  11. Gen1Gen2sofar
    Gen1Gen2sofar DIYR Mech Elec Engr
    Baraboo
    Oil Type: Syn
    Brand: Mobil 1 5w30 5000 mile change on both Gen 1 (5 mile one way to work) with 145k and Gen 2 (44 miles a day)with 65k. Fram Tough Gard almost 100% of changes. Buy on sale local Farm and Fleet...
    Neither '03 or '07 Prius burns or leaks any oil. Dipstick always just under full. Have found better to fill slightly below full at change for milage,,, may be windage losses with higher oil level?
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    Oh yeah, 5W30 always. Yes, I noticed that it is a blend. I should put a vote in the synthetic blend column then and join those other two lonely people. I have been getting the regular red container but the NextGen green bottle reads, well, pretty green. Recycled oil is oil after all. Have to check the price.
  13. krmcg
    2,592
    2,392
    Whittier, CA
    Mobil1 Adv Econ Synthetic 0W-30. I change oil every 6,000 miles.
