Which one? Same price for 2016 vs. 2017, but...
Discussion in 'Gen 4 Prius Main Forum' started by R000se, Apr 13, 2018.
  1. R000se
    R000se New Member
    Hello friends,
    Moving over to our first Prius. I came across two options and wanted to get your thoughts:
    1. 2016, Prius 3. Advanced Tech Package. ~14k miles for $21,000. Dealers fleet car.
    2. 2017, Prius 3. Advanced Tech Package. ~14k miles for $21,000.
    The main difference is that the 2016 comes Toyota Certified, which means I have 7yrs/100k miles warranty on engine/transmission. However, the 2017 is being sold by a Lexus dealership and I get the standard warranty.
    A few questions:
    1. It's basically a tradeoff between Toyota Certified and a newer year. Which one is the better route?
    2. Should I concerned of 2016's since it's the first year of the new gen?
    3. How does the pricing match up to what you folks have seen? I checked out KBB and these seem like good deals.
    Thank you!
  2. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    They are both the same car. There aren't any real differences between model years from what I understand. I may be wrong. I think what you need to do is determine if the difference between depreciation rates is worth the warm fuzzies of the seven year warranty. If I were making this decision I'd be thinking how long I'm going to own this car. If you are going to drive it until the wheels fall off, I'd go for the 2016 model.
    BUT, I'd also check to make sure that Toyota won't honor the full warrantee, even if it is a used vehicle. After all, Lexus IS Toyota.
    R000se, pilotgrrl, RCO and 1 other person like this.
  3. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I would go with the 2017- newer is always better and the fleet car would give me some concern. Good luck!
    R000se and RCO like this.
  4. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    There was a time not long ago that I could detail exactly what each option package include for each year.
    Now, not so much.
    I would still suggest that you not assume all features are 100% identical, just because they have the same package, however.
    You might find one year has the Blind Spot Monitor (something hint I could not live without) and the other does not, for example. Or not. I am ex spurt.
    Ther is so much tech, that I sincerely believe even the most motivated could miss something with out a check list in hand at the dealership.
    Just my .02
    As for working with a Lexus dealer vs Toyota that hardy matters (apart from the longer Certified warrantee) since ther is zero reason why one should get their car serviced where they purchased it.
    R000se, pilotgrrl and RCO like this.
  5. R000se
    R000se New Member
    Thanks, @MichelleStone.
    @stephensprius -- You think the newer compensates for the extended warranty on the 16?
    @ATHiker -- Thanks for the thoughts. Looking through the online listing -- both look identical, but I do get your point. Assuming the two cars are identical, would you sacrifice a year for the warranty?
    #5 R000se, Apr 13, 2018
    MichelleStone likes this.
  6. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    I’d go with the ā€˜17 just because any bugs were worked out. You also have the remainder of the 3/36,000 bumper to bumper as well as the 5/60,000 Powertrain and 8/100,000 mile battery warranty (10/150,000 states with California emissions)
    What I noticed with the latter half of 2017 production, they started coming with
    Safety Plus Package (~$1000.00) that was included for free.
    – Blind Spot Monitor (BSM)37 and Rear Cross-Traffic Alert (RCTA)38
    – Intelligent Clearance Sonar (ICS)35 with Intelligent
    Parking Assist (IPA)36
    Not sure if that one has it but I would want it if I had a choice next time!
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Drive them both - see which one you like best. Colour?
  8. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I have the 2016 with the Advanced Tech Package. If I could get a new car now, I'd love a Prime or a 2018.
    In your situation, I'd go for the 2017. It's newer, has the complete TSS-P, which the 2016 doesn't, and you don't have to worry about the 2016's teething pains. Toyota's got those worked out. I haven't seen any recalls for 2017s here on Prius Chat. There were a number of issues on early builds of the 2016s.
    R000se, RCO and Tande like this.
