Which Prius for me?
Discussion in 'Gen 3 Prius Main Forum' started by Pasaman, Sep 28, 2012.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Did someone actually bring up nickel mining again? LOL
    dmvp likes this.
  2. miscrms
    miscrms Plug Envious Member
    2,079
    525
    Phoenix, AZ
    PiP sounds like a pretty good choice based on your needs/desires. Geek factor of plugin is hard to beat. Mild climate + short commute should do pretty well at maximizing EV driving. Free charging at work is a definite plus, and should cover your ~6 mile round trip so not charging at apartment is less of a big deal. May end up using a little more gas for weekend driving though, but 50-55mpg doesn't suck. When your commute gets longer, you'll most likely be able to charge at home and work. Full size Pius is a great family car when that day comes. Its certainly not going to pay for itself, but it sounds like that's not really the OPs goal.
    FWIW I disagree with dopey's comment as well. I don't think there is any reason to suspect that driving "only" 6 miles a day in a Prius is going to damage the traction battery. There could be extreme low usage cases where this might be a concern, but this hardly seems like one of them. In a PiP you'll only use about 1/2 the battery range typically, but if anything that should extend the life of the pack. I'd still charge it every day rather than skip a day just to deplete the battery.
    If you were trying to maximize your value for money, the recommendation might be different. But if its down to a C, a Prius, or a PiP all equipped to have similar cost, I'd go PiP!
    Rob
    F8L likes this.
  3. miscrms
    2,079
    525
    Phoenix, AZ
    LOL :) Thats pretty much where the credibility went out the window ;)
  4. miscrms
    2,079
    525
    Phoenix, AZ
    That's only been debunked since about a month after it was trotted out by the oil companies ~5-6 yrs ago. Mining sucks for the environment. No question. But how do you suppose that the mining of 40-50 lbs of nickel, which is not particularly unusual as a metal or toxic as a substance and is recyclable, is far worse than the mining of the ~ 3-5000 lbs of iron, nickel, copper, aluminum, lead, petroleum derivatives, etc that go into a typical vehicles construction? Or how do you suppose it would be worse than the extraction, refining, and burning of the ~48,000 lbs of gasoline, which is fairly toxic and hazardous, a typical vehicle will use over its lifetime?
    Rob
  5. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    I forgot about your charging situation at home. That could make it tough to have a PIP. Good shopping!
  6. Pasaman
    Pasaman Active Member
    289
    111
    Southern California
    My work has 25 charging stations of which 2-3 are used daily. It is in a very safe location where I have no fear of cables getting stolen. We are looking to rent a house so we may be able to charge there.
    On the flip side I'm intrigued by what options I can get for a 28k regular Prius. What could I expect for around 28k in a regular Prius?
  7. wanaset
    wanaset Junior Member
    86
    16
    For 28k you can get the Prius 5. I would still decide against the PiP unless you really want one. Here are the options of different trims - Toyota Prius - 2012 Options and Packages.
  8. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    Since you had expressed a desire for a sun roof, a Prius Three with a sun roof and nav should run about 28 k.
  9. Pasaman
    289
    111
    Southern California
    Is 28k really the going price on the 5? I see the price starts at $30,600 when I build one on Toyota's website.
    As the poster above mentioned I see the 3 with solar moon roof coming in around 28k.
  10. wanaset
    86
    16
    Sorry, I meant the 4.
  11. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    If you're in Seal Beach, then it's not that far for you go-go uptown to Carson Toyota, just on the other side of Long Beach and deal with Dianne Whitmire. This is a complete no-brainer. You live that close. She'll set you up in whichever one of the Prius fambly you'd like. She owns and drives Prius. So you know what she tells you will make sense. She can also help you think through the apartment question. At any rate, you're a hop-skip and jump from Carson. You'd be foolish not to at least talk with her even if you decide to buy somewhere else. I doubt you will, however. She knows the ins and outs of the car as well as the best deals that are out there. You won't be dealing with someone who just sells cars for a living.
    She's sold hundreds of PiPs already, and the cars haven't even been on the market for a year.
    rogerv likes this.
  12. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Give Dianne a call for sure. Don't talk to anyone but her or her assistant, Nathan. (310) 522-2317 office; (949)689-0717 cellphone. Good luck. (and for what it's worth, I would go for the PiP in your situation, as long as the moonroof isn't a deal-breaker)
  13. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    It might be tough to swing a Prius 4 with an Out the Door price of $28,000. You could (likely) negotiate to 28,000, but then you'd pay the tax, license, destination (etc) and it would be closer to $31,000. The "problem" is that (for the 2010 and 2011, you had to get the NAV with a package 4. See if the Toyota website will let you build a Prius in CA (4 or 5) for 28K.
