Which Spark Plugs?! Denso SC20HR11, SC16HR11, or IXEH20TT??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HaiImBrian, Jul 11, 2018.
  1. Denso SC20HR11 (Original in manual)
    40.6%
  2. Denso SC16HR11 (New hotter plugs that Toyota superseded original plugs)
    34.4%
  3. Denso IXEH20TT (Brand new tech offered by Denso)
    25.0%
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    But it is not clear that carbon on the plugs is the ONLY thing that will cause "pinging" noises in the engine.
    Because it isn't.
    sbfoster777 and Mendel Leisk like this.
  2. sam spade 2
    7,035
    2,801
    2017 Prius c
    All sparks of the same length and same voltage are identical.
    All spark PLUGS are not identical.
    In addition to different gaps, the plug contributes to the overall "fluid" dynamics inside the chamber and that is important too.
    I did NOT say that all plugs are the same.
  3. sbfoster777
    sbfoster777 Junior Member
    Thank you Sam. I'll pull them and take a look.
  4. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    The 20's are OEM for many car from Toyota, Nissan, and even Mercedes along with other makes. I don't think they are going anywhere if they are used for so many cars. My 2017 Corolla iM and 2009 Corolla S both use the same 20 plug.
  5. SuperchargedMR2
    673
    179
    Vancouver, WA
    I tried to find a colder plug to use in my 2009 Corolla S which I turbocharged but nobody made anything colder in this size so I'll stick with the 20's for that car. I wish that Denso made one step colder as that would be preferred with the turbo but it has run great with the 20's. I'm thinking that the Prius will run just fine with the 16 or 20.
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I hope you don’t miss the time requirement by 2 years....
    Regarding which plugs, I'd go with what Bosch says, I believe 9621, for the engine in our v it notes:
    http://www.boschautoparts.com
    #26 jzchen, Feb 4, 2020
  7. Mendel Leisk
    41,412
    Apologies, Canadian schedule is same as the States: 144 mo (12 years) or 192,000 kms (120,000 miles), whichever comes first. Excerpt from a 3rd gen Canadian schedule (2014, which had a nice graph format, for a change):
    (Full schedule attached)
    Phone up a dealership part dept. to check, but I'm pretty sure they switched to 16 (hotter) for the Prius. Not a lot of difference I think: I've pulled ours (20's) for a look and they looked pretty clean.
    #27 Mendel Leisk, Feb 4, 2020
    Fostel and jzchen like this.
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    No need to apologise Mendel. I just noticed the type of math mistake that I make all the time. Thanks for sharing. I didn't know/think about a spark plug needing changing based on time. I've read of it, asked, and was just told not necessary...
    moto g(7) power ?
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Mendel is right. Toyota said switch to hotter 16 plugs to reduce carboning. I swapped in 16s when it was time .
  10. Mendel Leisk
    41,412
    Hey, I'm Canadian... :rolleyes:
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Hmmm. Hard to believe, "eh"....
    moto g(7) power ?
    Glojazzbent likes this.
  12. alexshock
    alexshock Junior Member
    UA
    Active
    Wow! 192000 km - how is that possibe?
    European Auris Hybrid has same powertrain as Prius, but service interval is 90000 km or 100000 km.
  13. alexshock
    UA
    Active
    I have just replaced (90000km): Toyota changed original 20 with new 16.
    Original sparks photo is attached.
    RastinoSLOVAKIA and Fostel like this.
  14. Fostel
    Fostel Member
    96
    29
    Kent
    Excel
    Manual from 2013 says DENSO SC20HR11 Gap: 0.043 in. (1.1 mm)
    I ordered a set from eBay a while ago and they came completely damaged (bent electrodes).
    Decided to get the spark plugs from a reliable source and went to a dealership.
    They naturally sold me hotter SC16HR11. Ten bucks more than eBay but I thought I am set.
    The thing is, when I measured the Gap it is at 0.040 in. (0.99 mm) and all four of them roughly within this range.
    1. Could anybody confirm what the Gap (measured) is on the new plug?
    2. Should I install them as is or gap them to the spec?
    I would risk gaping one that is out of the spec but do not want to gap all four as I only have a coin type gap tool. Additionally, they seem to come like this, from the factory.
    3. I am at 86k miles. Should I replace them now or wait a bit more?
    4. I postponed this a while now as I've got no air compressor to blow dirt from the plug holes. Any hacks? Will canned air be sufficient? Some videos I've seen, they skip this part altogether.
    DENSO SC16 Spec is 0.043 in (1.1 mm):
    SC16HR11
    Car manual says:
    Denso says:
    Should I Gap My Plugs?
    #34 Fostel, Sep 16, 2020
  15. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    You're a bit early for new plugs, by the odometer, but if you have the cowl off for any reason, like for inspecting the EGR system, switching the plugs is easy. Blowing some canned air should do the job--the plugs are covered, so not much dirt or grime is present.
    It's a little controversial here, but Denso says not to adjust the gap:
    P. 64. DENSO Spark Plugs are manufactured with a pre-set gap. With nickel plugs, especially with motorcycles, the gap may need adjustment. Always use a special spark plug gapping tool to change the gap. Do not change the gap on platinum, iridium or Twin Tip spark plugs, as the fine electrodes may get damaged.
    https://www.denso-technic.com/images/document/ignition/en/spark-plugs-manual-en.pdf
    #35 pjksr02, Sep 16, 2020
    Fostel likes this.
  16. Mendel Leisk
    41,412
    I'd be inclined to leave them as-is. Unless grossly off, then I'd return/exchange them. I'm in the camp that you don't adjust the gaps on these. Also don't clean with anything abrasive, down the road: just something like carb cleaner and old tooth brush.
    Spec for new plugs, from the Repair Manual:
    Full info in attached.
    pjksr02 and Fostel like this.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    :LOL:
  18. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    It's going to be a long while, but I'm going to get Bosch plugs...
    moto g(7) power ?
  19. Fostel
    Fostel Member
    96
    29
    Kent
    Excel
    THANKS for the manual!
    It seems, that they are within the service specified range at rock bottom 0.039 in.
    I took some pictures as the electrodes are looking nothing like DENSO pictures (maybe models/renders?).
    Denso pics: Clean, cylindrical shape with some height
    Real pics: Irregular, flat, weld-like blob
    IMG_20200916_163613.jpg IMG_20200916_163358.jpg IMG_20200916_163551.jpg IMG_20200916_163156.jpg IMG_20200916_163250.jpg IMG_20200916_163512.jpg
    I do not want to do this job twice so wanted to make sure they are the real thing. I have no other plugs to compare with atm.
    Is this how the electrode should look like?
    Mendel Leisk and pjksr02 like this.
  20. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Good pics. Thanks.
    I have never seen anything like that - irregular shaped, looks like a squashed clump of something rather than a precisely cast or machined material.
    The ones I have seen (not this specific plug model) always look precise, a lot closer to the stock photo you show, vs. the actual photos.
    With spark plugs, fakeness should always be a major concern. Kind of shocking that you got them from the dealer. I'd take them back and see what they have to say about it. And if they don't give you replacements that look closer to the stock photo, I'd return them, and look elsewhere, or leave your original plugs in the engine. Quality, genuine, double Platinum / Iridium / Ruthenium plugs should last well over 100k miles in most engines.
    If they try to blow you off and shame / ridicule you for doubting the dealer, that's just what dealers do. Don't fall for it.
    Mendel Leisk and Fostel like this.
