Which stations have less ethanal??
Discussion in 'Prius c Main Forum' started by SuperABM, Oct 24, 2012.
  1. SuperABM
    SuperABM Junior Member
    71
    Orange County, CA
    I
    I've noticed only some gas stations show on the pump how much ethanal they have. What about the gas stations that don't show it? Am I just looking in the wrong place?
    I was at a mobile the other day and it didn't show how much on the pump so I asked the cashier and she said she didn't know.
  2. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    It's supposed to be labled somewhere. If you don't see it, don't buy it.
    I never buy it, regardless.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have noticed this and asked at one station and was pointed to a decal on the side that stated that the gas "May contain as much as 10% ethanol". The attendant had no idea how much ethanol was in there or whether there was any at all. He said they never tell them info like this.
  4. SuperABM
    71
    Orange County, CA
    I
    Most gas stations I've been to don't state how much they have :(
  5. SuperABM
    71
    Orange County, CA
    I
    Is it safe to assume that if its not labeled that they use ethanal free gas? It's not like I'm going to thrifty gas stations, I only go to 76, mobile, Chevron, and shell.
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    You are more likely to get a higher percentage of ethanol in mid-grade or premium, since ethanol cost more and is an octane booster.
    In the winter blends, they choose to put less ethanol in Regular.
  7. Mr Incredible
    955
    506
    Neb
    Ethanol must be labeled around here. If it isn't labeled as ethanol it should be 100% gasoline, either regular (87 octane) or premium (91 octane). The middle pump button is the ethanol blend with an octane of about 89.
    Some areas must have ethanol in all their blends. This is not one of those areas so I don't know what their pumps look like.
  8. SuperABM
    71
    Orange County, CA
    I
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Thanks for the website. I see now how NC stations get away with the "May contain up to 10%" labels.
    North Carolina - NC (House Bill 187 passed in 2011 now requires labeling but "not enforced".)
  10. Mendel Leisk
    42,096
    In Canadian Chevron stations there's one label for the lower 3 grades saying "may contain up to 10% ethanol", and the fourth, highest grade label say's "contains no ethanol".
  11. Mike500
    2,593
    767
    Guess isolating those gasoline molecules with 8 carbons in the chain without the use or an octane booster like ethanol requires a more expensive process.
    Tetra ethyl lead and MTBE is no longer allowed, so either isolating the 8 carbon chain gasoline molecules or using cheaper grades that include a mixture of 7 or even 6 molecule chain compounds, or ethanol are the approved methods.
  12. Wiscott
    Wiscott New Member
    I have a question about ethanol blended fuel. If the price of gas keeps dropping and drops by another 20 cents or so in my area I am considering getting the premium gas here that has NO ethanol in it. It costs 30 cents a gallon more than no lead but I am wondering would I get even better gas mileage? Has anyone ever put premium gas with no ethanol in their tank and did you notice any gas mileage difference?
  13. SuperABM
    71
    Orange County, CA
    I
    Does premium gas have no ethanal?
  14. fuzzy1
    10,630
    Premium has little or no impact on mileage, depending on who is making the argument or doing the empirical testing. But no-ethanol definitely helps mpg a bit. Theoretically, the boost is a bit over 3%, and the controlled tests get about that amount. But numerous users in uncontrolled tests have claimed 10-20% gains.
    It depends on where you are. Many areas have ethanol in all fuel grades.
  15. Wiscott
    Wiscott New Member
    ok thank you. Yes only the premium gas here has no ethanol. The regular no lead and super (mid grade) have 10% ethanol here.
  16. SuperABM
    71
    Orange County, CA
    I
    Where do you live Wiscott?
  17. DanManTX
    DanManTX Junior Member
  18. SuperABM
    71
    Orange County, CA
    I
    Too bad for Cali we only have a few in the middle of no where ..
