Which tires for higher gas mileage?
Discussion in 'Prius c Main Forum' started by bountybuddy, Dec 25, 2014.
  1. bountybuddy
    bountybuddy New Member
    Caro, Michigan
    Hi everyone. Please let me know which tires you are using for the highest gas mileage. I'll give them a try when I have to replace my tires. Thanks very much. Drive safe my friends.
    52,927
    there may not be anything better than the oem's, mpg wise, but the michelin energy saver a/s should be equal and quieter, better ride and longevity.
  3. mahout
    mahout Active Member
    655
    116
    NC
    running in mpg contests the skinner the tire and the higher the tire pressures yielded highest mpg, over 120 mpg over tricky routing.
    For the prissy, one of the Low Rolling Resistance tires in a 165/50x17 tire at 48 psig will yield the better mpg when the wheels are 5" or 4.5
    ' rims and as light as poxssible, about 12 to 13 lb as I recall. The tire above is close to the OEM and lighter so the engine works a lot less to move.
    Needless to say, those aren't autocross tires so don't expect to carve corners. if contesting shave the treads to 1/8".
  4. blue-skys
    blue-skys Junior Member
    Tempe, Arizona
    not sure if it would make sense or if its possible but, what about just going an inch taller tires?
  5. Mendel Leisk
    42,387
    OP, is this for a Prius c? What level? Tire size?
    If it's 175/65R15 size, the LRR champion would be Michelin Energy Saver A/S.
  6. fuzzy1
    10,724
  7. mahout
    655
    116
    NC
    i agree
    I agree, with data. The customer who tri4ed them consistently got 50+ mpg and with his hipo tires got 42-46 and he doesn't try for high mpg. When he switched bad for performance I asked him he wanted to sell his but no, thats what he'll mount when he sells. His Mich's just gather dust now.
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    +1 they were good for +3MPG on Gen3 (vs OEM Yoko)
