Which Tires Wear Fastest-The Fronts or Backs?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Mar 18, 2026.
  1. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    A driving pattern could cause that kind of minor variation.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    546
    New York State
    2026 Prius
    @mva , maybe that's why they supply non-unidirectional tires, for stock anyway.
    The manual probably shows front to back because of the ultra lux 19" tires.
    I have to see if I can quantify, to some degree, from my records.
  3. VelvetFoot
    1,408
    546
    New York State
    2026 Prius
    Tired of the winter weather though.
    Still hoping for April 1st tire change out though.
  4. Mendel Leisk
    42,365
    It's been thus for some time, for gen's with 15" base tires.
    Gen 3:
    Gen 4:
    That 4th gen full-size spare rotation guidance would lead to right side wear out of sync with left methinks. Only temp spares were used (on certain levels, typically the lower levels, go figure...), at least in North America.
    Somewhat suprising, gen 1 and 2 Owner's Manuals just say to rotate, don't specify how.
    #24 Mendel Leisk, Mar 20, 2026
  5. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    The Toyota manuals show them front to back since the 1980s, probably to keep things simple and make the recommendation compatible for unidirectional tires, but the correct way to rotate bidirectional FWD tires is:
  6. Mendel Leisk
    42,365
    Well, I've been doing it incorrectly for 15 years, per the Owner's Manual for my 2010. One upside: next to no curb rash on the left-side rims.
    FWIW, for decades of Hondas it was straight-back-and-cross-to-front.
    Gokhan likes this.
  7. Gokhan
    6,715
    2,672
    Paramount CA
    Definitely incorrect, yes. Toyota’s recommendation will result in uneven tread wear.
  8. Mendel Leisk
    42,365
    The elephant in the room: that tire shop that doesn't label tires as they come off. Maybe a new guy??
    Tried googling:
    is it tire shop rule number one: always label tires for location, when removed from vehicle?
    AI concurs
    Gokhan likes this.
  9. Gokhan
    6,715
    2,672
    Paramount CA
    You can identify the tires by the painted dots on the sidewall. They are positioned differently for each tire.
    Here are my beautiful Dunlop Enasave 01 A/S 91S tires with my beautiful aero wheel covers and beautiful OEM Pacific Industrial Co., Ltd. tire valve caps on the Turquoise Jewel.
  10. Mendel Leisk
    42,365
    This helps when they're all lying on the slab?
    Calm down now.
  11. Gokhan
    6,715
    2,672
    Paramount CA
    Why become hostile over something like this?
    The dots (red and yellow in my picture) are unique on each tire. You can take a photo before rotating them. They help you determine if the rotation was done correctly. Tire technicians will simply position the tire where it needs to be rotated immediately after removal, so they don’t need identifying marks.
    #31 Gokhan, Mar 20, 2026
  12. Trollbait
    12,832
    That's how Toyota wanted to rotate tires for non hybrids too.
  13. VelvetFoot
    1,408
    546
    New York State
    2026 Prius
    It was a new guy. He's the guy who also lost my OEM valve caps, lol.
    Mendel Leisk and Gokhan like this.
  14. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Toyota USA only. Toyota manuals elsewhere show the more generally recommended cross from back to front.
    Trollbait and Gokhan like this.
  15. Mendel Leisk
    42,365
    Right you are, from a pdf of the Toyota Australia 2010 Prius Owner's Manual:
    Interesting response from AI when googling:
    Why does Toyota recommend simple front to back tire rotation in North America, but cross rotation elsewhere, Australia for example
    I may be a convert; cross-rotation has been the norm with every Honda we had over the decades. Apart from snow tires with directional tread. That said, I've had no problems with the Toyota Canada recommendation to keep them on the same side.
    #35 Mendel Leisk, Mar 21, 2026
  16. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    I've just been rotating my tires in a clockwise fashion for the past two decades. I've found that the cross rotation makes the car "feels funny" for a few hundred miles after the rotation. I don't get that weird "drive feel" when doing a clockwise rotation.
    YMMV
  17. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    And in Canada too!
    It could be to avoid getting directional tires turning the wrong way.
    Also, first time I’ve ever heard of clockwise rotation.
  18. Gokhan
    6,715
    2,672
    Paramount CA
    It is a no-brainer. If you keep the tires on the same side when you rotate, the two sides of the tires will wear unevenly, and the tread will eventually look slanted. There is no reason to do that unless the tire is directional or there is a specific recommendation from the tire manufacturer.
    In any case, it is silly to adhere to the vehicle manufacturer’s recommendation in this case, as you should be adhering to the tire manufacturer’s recommendation.
    frodoz737 likes this.
  19. alyssagrey
    alyssagrey New Member
    United Kingdom
    2024 Prius
    Hey, from what I’ve seen it’s generally better to put the better tyres on the rear. Even if the fronts wear quicker, having more grip at the back helps keep the car stable, especially in wet conditions. I’d just rotate them from time to time as well to even things out. I was actually looking around for some general tyre info the other day (just comparing a few things online), and came across TyreSavings while browsing — but the general advice I kept seeing was the same about keeping the better ones on the rear
  20. TGTGUUD
    TGTGUUD Member
    100
    77
    San Francisco
    2024 Prius
    36k miles on my 17" TOYOs. I did 2 rotations myself since the free services ran out.
    Front wears faster, left front the fastest.
    VelvetFoot likes this.
