Which way is the Prius c tire thread??
Discussion in 'Prius c Main Forum' started by Leadfoot J. McCoalroller, Jun 16, 2018.
  1. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Hey I know y'all have one hiding around here somewhere, a thread with a list of all the tires anyone bothered to try and post about. Right? Or maybe we get to make one?
    I'm trying to make some decisions for winter. Everything I've read about the Prius coupled with everything we have experienced in gas-powered FWD cars tells us we are going to need snow tires for this c.
    I have a set of rims lying around from another car. I haven't done a test fit yet, but from the specs it looks like they will match up. However, they're 14", which limits the actual tire choices. I found a Nitto NT-SN2 in 195/65R14 which would match the stock tire outer diameter. I've never had a Nitto tire, do not know anything about their winter grip- anyone?
    We find that it is worth hanging snow tires from late November through mid-March, maybe April 1 around here.
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Your right, somewhere around here is a thread. Not specific to the "C" however if I remember right. Not sure how much snow you get over your way but if it helps to know, we had a few good snows around my area last year. Couple around 4-5", but the stock tires never gave me an issue. I'm assuming yours are Bridgestone's as well? (We mostly get slick roads due to ice/sleet here where I live).
    The 14" rims may be enough to throw a code on the "C", so that may be something to consider. Now sure how much they can adjust for at the dealership for different tire sizes. So before buying any tires or even test fitting, it might be worth a call.
  3. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Well hang on, ours showed up with Goodyear Assurance fuel-max-o-tron pro gold or whatever. Anyway it's a goodyear in 175/65R15, and I've got a tire size calculator telling me that the outside diameter of that setup is 24" overall; 872 revs per mile. The Nitto I found is 24.1", 861 revs per mile. You don't get much closer than that when shift-sizing tires.
    How sensitive is this computer anyway?
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Couldn't tell you how sensitive it is, but that is pretty close.
  5. Mendel Leisk
    38,726
    Better do a test fit fit first; will these 14" rims even clear the brakes?
    As far as I know, the only thing that would upset the car would be using a variety of tire outside diameters, say 3 the same and one odd-ball.
  6. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    I will test hang a wheel to verify. I figured a prius wouldn't be likely to have large brakes, but you never know.
  7. Mendel Leisk
    38,726
    I'm using Corolla 15" steel rims with snow tires on our 2010 Prius; they're fine, but looking through rim opening the caliper shoulder is really close, less than a finger width I think.
  8. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    mind you, this is going onto a c. Everythings a bit smaller.
  9. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    I have Insight 14” RE92s on my Cobalt at the moment , even after the odometer correction they gave a good FE boost over stock, tempted to leave them on.
  10. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Kicking this thread with an update.
    Today (April 13 2024/81k miles) we retired the factory Goodyear Assurance tires and installed Continental True Contact Tour tires. Premium stuff; the ride is dreamy.
    More detailed review to follow.
    Pri3C likes this.
  11. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    This is a silent squidgy tire. I was all set to go for the General RT43, a known quantity for a quiet comfortable tire. Well, they aren't made in our size anymore. It has been replaced by the RT45.
    I'm sure the RT45 is a lovely tire, but once we are away from an old favorite...
    I talked to a buddy and he suggested these. I'm really happy with them.
    Even on the loud pavement types near me these things eat up the buzz.
    The car is more relaxing to drive and the stereo sounds twice as expensive.
    Of course, the gas engine seems louder when it kicks in.
    These tires feel great so far, but I haven't driven them that much or in iffy weather yet. more details and MPG comparison later as well.
    #11 Leadfoot J. McCoalroller, Apr 14, 2024
    Pri3C likes this.
  12. Pri3C
    Pri3C Active Member
    180
    127
    Midwest
    2014 Prius c
    @Leadfoot J. McCoalroller I have the True Contact Tour as well + some snow tires. We had such a mild winter I opted to leave them on this year, and while I could tell a difference between them and the snow tires, they did fine in the little bit of snowy weather I drove in. Solid all season tires. Handles wet rainy roads well.
