Which way to install cabin air filter?
Discussion in 'Gen 3 Prius Technical Discussion' started by ePRIU$, Feb 26, 2019.
  1. ePRIU$
    ePRIU$ Junior Member
    35
    When I took out the cabin air filter, I don't see any arrow direction at all on the old one. My new one has arrow direction like home A/C filter. Which way should the arrow points to? thanks.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Some have an arrow with “UP”. That one is obvious. Some just have an arrow which is direction of airflow. (Hopefully someone else can confirm).
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Shoot. Did this 2 weeks ago with a Toyota OEM cabin air filter. Recall that there is a fat arrow with “UP” embossed on the end that you can see when you insert it into the plastic frame in back of the lower section of the glove compartment. I appear to have thrown out the old one, so no pic.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    It's designed so that junk that gets through the intake screens lands on top of the filter and stays there. That would dictate that the air flows downward.
    Robert Holt, tvpierce and WilDavis like this.
  5. ePRIU$
    35
    You are good, Jerry! Thanks.
    jerrymildred and bisco like this.
